Tail light condensation
Old Dec 31, 2015 | 04:57 PM
Lveyolfe's Avatar
Lveyolfe
Default Tail light condensation
Ever since I used actual water to wash my car, (I always steam clean it) there has been condensation build up in the corners of the tails. Any ideas to make it go away?! Besides ripping out the housing, un-gluing it, etc..
Thanks!!
Old Jan 1, 2016 | 01:17 AM
salimshah's Avatar
salimshah
25 Year Member
For condensation, there are two things ... entry and exit.
Every one assumes a break in the seam allows entry of water. For this to be right the water must accumulate and then drain in from where the break is. Remove the tail light and study that and seal the entry point. You can seal al the seams by laying a thin bead all around.
I would also look for crack(s) in the lens.
Finally check that the drain pipes are clear. They look like "L" shaped pipes at the bottom of the lens assembly.
You can use hair dryer to remove inside condensation. Low humidity days are better days to dry out the lens.
Salim
Old Jan 1, 2016 | 03:58 PM
Lveyolfe's Avatar
Lveyolfe
Thank you!
Old Jan 15, 2016 | 08:28 PM
newbee's Avatar
newbee
9th Gear
Default Warranty Enhancement Program
Salim
I had a headlight replaced before the end of a warranty enhancement program...condensation. Will Lexus be mailing out a program for condensation in a rear light, soon? I've got the problem.
Old Jan 15, 2016 | 08:30 PM
newbee's Avatar
newbee
9th Gear
I've got condensation in ONE tail light. I already had a head light replaced due to the same problem by means of a Warranty Replacement that I received in the mail from Lexus. Will a Warranty Replacement be mailed out soon for condensation in a tail light?
DennisMik
Apr 20, 2016 11:57 AM
Majek
Mar 8, 2015 12:37 AM
afang
Apr 22, 2009 07:58 PM
KPC
IS - 1st Gen (2001-2005)
12
Feb 11, 2007 06:05 PM
thebanez
Sep 3, 2005 02:20 PM
