Timing Belt is now replaced
There are a bunch of "special" tools that the service manual refers to that are to be used. One is the crank tool, but there are some other special tools called out as well. Did you use substitute items, or did you get all these specialized tools?
I will be doing the belt on my 93 400, so I wanted to check before I get into it.
Thanks!
928
the manual specified taking the sprak plugs out. don't do it. leave as much attached as you can. you have to take loos the idlers, fan pump and alternator. I took the 2 front bolts out of the a/c, but left it hanging.
you might want to also replace your rotors and rotor caps as well. It's only an extra 60 clams, but it's an easy change while you're up in there.
That spcl tool made all the difference.
Good luck ya'll
Frank
I am ordering the stuff from Carson Toyota now.... I would HATE to take it all apart this W/E and find out that I couldn't get the crank pulley off.
Looks like I will have a busy weekend!
Thanks again!!!
928
One other thing. The Service Manual says you need to remove the crankshaft timing pulley (yet another tool). I don't see why that is required, as the belt slips off that. If I wanted to change the front seal, I could understand. Did you pull that pulley (gear)?
Thanks,
928
-scott
I bought all new belt idlers and the tension gizmo. I figured once I open this up, I don't want to do it again for another 100k miles. I also will change the water pump, so every stinking part will be new. If I had this done at a dealer I bet it would run $2k.
I also bought brake pads and shimm kits. For the whole bannana it was 500.00 and change for Govener Davis w/othe water pump (I have a brand new ABSCO I had bought some time ago, they are Toyata's parts supplier in Japan). Sound like a lot, but when all said and done, the front won't be comming appart for a long, long time.
928
