Check engine light code 25
Old Aug 31, 2015 | 10:08 PM
Barbary's Avatar
Barbary
Default Check engine light code 25
Check engine light comes on at times_____92 SC 400
code 25 = Air–Fuel Ratio Lean Malfunction
is it a problem? and whats the best solution? I've searched the forum, haven't come up w solution. Lexus wants $175 for engine inspection. Shop low to read code $125
Thanks for any help
Old Sep 1, 2015 | 07:14 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
https://www.clublexus.com/forums/per...lfunction.html
https://www.clublexus.com/forums/per...2-sensors.html
https://www.clublexus.com/forums/sc-...-25-obd-i.html
https://www.clublexus.com/forums/per...code-25-a.html
o2 sensors
Old Sep 2, 2015 | 12:18 AM
Barbary's Avatar
Barbary
Default Bvance
Thanks Slide it was all helpful, probably gonna save $100's. I've done some stuff, right now the light isn't on & the Bullet still runs great, but at 1/4 mill miles I'm sure stuff happens & I'll be ready
Bvance was the best. Hopefully I'll be able to find this on my own someday :thumb up:
Old Sep 2, 2015 | 10:49 AM
EPayne42's Avatar
EPayne42
I have the same code currently on my 1995. I'm gonna start by looking for vacuum leaks. I have a few vac lines that are pretty tired.
Old Sep 21, 2015 | 09:41 AM
durps's Avatar
durps
Had the code before on my old sc400. It was the o2s. You can get them cheap online, either ebay or amazon. Only use densos, go on their site. Put in your car's info, take down the part # and put it on ebay. I scored mine for $35 each, oem replacement.
diverchris
Dec 27, 2010 07:43 PM
acc
Jun 10, 2010 09:49 PM
Pirates81
RX - 1st Gen (1999-2003)
Sep 14, 2006 03:55 PM
bored7one4
Aug 11, 2005 10:11 AM
SCdrifter
Dec 18, 2003 08:44 PM
