sc400 does not start
Old Apr 14, 2015 | 12:41 PM
clamsoup's Avatar
clamsoup
Default sc400 does not start
Ok so I am a new owner of a sc400 1994.
Drove it for about a week and then the engine started misfiring, engine codes were 25 and 26, running lean and running rich.
One day the car would not start. I have changed the fuel pump, caps and rotors. I am getting good fuel pressure and spark is across all cylinders.
The timing belt looks worn but I am not sure this is the cause. Another mechanic has suggested Crank position sensor or cam position sensor.
Right now when I have the diagnostics jumped with a wire the engine check light flashes on and off continuously and wont stop flashing.
Does anyone have any idea what it could be?
Old Apr 15, 2015 | 11:35 AM
clamsoup's Avatar
clamsoup
anyone know what this could be?
Old Apr 15, 2015 | 02:56 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
How many miles? Has the ECU been checked yet?
Old Apr 15, 2015 | 03:52 PM
clamsoup's Avatar
clamsoup
269K miles! its alot, the ecu is now out and everything looks pretty clean, should I just have it rebuilt just in case?
Old Apr 15, 2015 | 04:05 PM
clamsoup's Avatar
clamsoup
I guess its hard to tell
Attached Thumbnails sc400 does not start-1429138396210.jpg   sc400 does not start-1429138418112.jpg   sc400 does not start-1429138428765.jpg   sc400 does not start-1429138442964.jpg
Old Apr 15, 2015 | 04:58 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Looks fine to me, but still Make sure to check real closely around the caps to see any gel leaking or stains. Also look for cap bulging.
Old Apr 15, 2015 | 06:03 PM
clamsoup's Avatar
clamsoup
I had another close look. looks very clean, no bulging or stains anywhere.
This is really bugging me. anything else that could prevent it from starting
Old Apr 15, 2015 | 06:13 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Well a few things to check would be the Trac TPS sensor (if you don't have one, that eliminates that as an issue) check your spark plugs/wires. Make sure they aren't arcing or brittle and stiff. o2 sensor(s) are likely the main issue here if they haven't been replaced in years. They are pretty expensive and if you go cheap you will need to splice the connections. Just for future reference here is a list of the OBDI codes.
lOBD1 Codes
1 Normal Condition.
2 Air Flow Meter signal.
3 Ignition signal.
4 Engine Coolant Temperature Sensor signal.
5 Oxygen Sensor.
6 RPM signal (Crank Angle Pulse).
7 Throttle Position Sensor signal.
8 Intake Air Temperature Sensor signal.
9 Vehicle Speed Sensor signal.
10 Starter signal.
11 Switch signal.
11 ECU/ECM.
12 Knock Control Sensor signal.
12 RPM signal.
13 Knock Control CPU (ECM).
13 RPM signal.
14 Turbocharger Pressure.
14 Ignition signal.
21 Oxygen Sensor.
22 Engine Coolant Temperature Sensor signal.
23 Intake Air Temperature Sensor signal.
24 Intake Air Temperature Sensor signal.
25 Air-Fuel Ratio Lean.
26 Air-Fuel Ratio Rich.
27 Sub Oxygen Sensor signal.
28 No. 2 Oxygen Sensor signal.
31 Air Flow Meter signal (Vacuum Sensor signal).
32 Air Flow Meter signal.
34 Turbocharger Pressure signal.
35 Turbocharger Pressure Sensor signal.
35 HAC Sensor signal.
41 Throttle Position Sensor signal.
42 Vehicle Speed Sensor signal.
43 Starter signal.
51 Switch signal.
52 Knock Sensor signal.
53 Knock Sensor signal.
54 Inter-cooler ECM signal.
71 EGR System.
72 Fuel Cut Solenoid signal.
78 Fuel Pump Control signal.
81 TCM Communication.
83 TCM Communication.
84 TCM Communication.
85 TCM Communicatio
Old Apr 15, 2015 | 08:32 PM
clamsoup's Avatar
clamsoup
thanks.
Plugs, wires, rotors and caps are all new and there is spark across all cylinders. I just put in a new fuel pump and there is good pressure right at the engine.
I havent checked the sensors, but ecu is clean.
So now I am thinking it could be clogged cats causing no start? since just before it died I could hear the rattling in the exhaust
Danny789
Jun 7, 2019 01:01 PM
TensorWorl
Feb 21, 2018 12:53 PM
KDSC400
May 15, 2013 02:47 PM
whiteysc
Aug 3, 2011 02:42 PM
tekkay951
May 13, 2010 11:31 AM
