A/C problem
Old Mar 10, 2015 | 06:58 PM
Cthopkinsc's Avatar
Cthopkinsc
Question A/C problem
What's up SC fans? Replaced outside air temperature sensor today. Correct outside temp now displayed. However a/c still only blows cold on max. When I adjust it to a warmer temp it blows hot. Check refrigerant level and all good. What's on the inside behind the 1'' square?
Old Mar 10, 2015 | 11:11 PM
t2d2's Avatar
t2d2
The cabin temp. sensor is behind that 1" square.
I would start by looking at the heater control valve and seeing if the actuator's rod is improperly moving through its full range of motion when you adjust the temperature just a bit. Another possibility would be the blend door, but I have no idea how to troubleshoot that.
Old Mar 12, 2015 | 11:21 AM
Cthopkinsc's Avatar
Cthopkinsc
Red face Questions?
Could the cabin air temperature sensor be causing the a/c to change from ice cold to hot when I try to adjust the climate control ****? I'll be checking the heater when I get home.
Old Mar 12, 2015 | 04:57 PM
t2d2's Avatar
t2d2
There are diagnostic tests outlined in the factory service manual for the cabin temp. sensor, but be prepared for a major PITA getting it unplugged. I partially busted up the sensor's housing and nearly broke the dash panel, and the sensor ended up being fine...
Old Mar 13, 2015 | 04:09 AM
Cthopkinsc's Avatar
Cthopkinsc
Default Location location
Where would the heater control valve be on the 95 Lex SC 4.0?
Old Mar 13, 2015 | 07:02 AM
t2d2's Avatar
t2d2
You'll find it on ... Google. Try harder, bud.
Old May 21, 2015 | 04:59 AM
SMWallis's Avatar
SMWallis
Default Max cool/Max heat problem
Did you ever resolve what was wrong with your system?
I have the same problem and have searched the archives for heater control valve, various sensors, air mix servomotor assembly and the climate control unit itself. I am leaning toward it being a problem with the air mix damper position/servomotor assembly. Maybe someone can share their experience with this problem.
Old Apr 22, 2016 | 07:35 PM
tkafam1's Avatar
tkafam1
i have the same prob. any advice?
mmatheny
May 19, 2016 07:01 AM
KingLS
Nov 13, 2014 05:53 AM
DONT SLEEP
Jul 28, 2010 06:15 PM
Blackxfire
RX - 1st Gen (1999-2003)
Feb 8, 2009 11:23 AM
