Texas Lonestar Drift LSx SC400 Build
Old Feb 20, 2015 | 07:59 PM
RotaSpinna's Avatar
RotaSpinna
Default Texas Lonestar Drift LSx SC400 Build
Hello, I'm Andrew. I reside in the northwest corner of Houston, TX. I may miss the first event of the season for the Texas Lonestar Drift Series, but fingers are crossed! PowerFab Automotive in Houston will be doing most of the drivetrain install and tuning, while Apex Auto Works in Angleton will be taking care of the cage and chassis prep.
The car is a 1994 SC400 with 171k on the chassis. I sold the engine to a friend of a friend who is putting it to good use in his Corolla GTS.
I'll be using your average 100k+ junk yard iron block 5.3 liter Chevrolet LS engine. Only modifications are LS2 intake, 90mm cable driven throttle body, LS1 camshaft, LS6 valvetrain, LS2 timing chain, Holley Accessory Kit, and Improved Racing F-Body Oil Pan kit. They make an EXCELLENT baffle. I used it on a RX7 build years ago. New gaskets and seals will be installed where needed. Not looking to spend a lot of money.
Decided not to use a T56 transmission. They cost too much money and I don't need the extra weight or gears. This is a track only car. For the time being, the transmission I'm using is a refreshed Borg Warner Super T10 4spd manual from a 1982 Chevrolet Camaro. It is a 26 spline input shaft, so any Camaro/Corvette Clutch Kit will work. These older transmissions are about .4" shorter, so a Chevy Truck flywheel has to be used. The bellhousing is a replica Chevy BBC "621" housing. Fits 11" clutch kits and bolts up to the LS just fine. Gearing is rather high though at 3.42, 2.28, 1.46, and 1.00. I plan on using the factory 3.92 SC400 differential, welded of course, so we'll see...
I purchased the mount kit from AMSmike here on the forums, but through his eBay account. Very nice items.
THANKS!
Old Feb 20, 2015 | 08:14 PM
RotaSpinna's Avatar
RotaSpinna
Old Feb 20, 2015 | 08:24 PM
RotaSpinna's Avatar
RotaSpinna
Old Feb 20, 2015 | 08:25 PM
RotaSpinna's Avatar
RotaSpinna
Old Feb 21, 2015 | 05:49 PM
RotaSpinna's Avatar
RotaSpinna
Torn down and inspected today. New water pump, LS2 chain, LS1 cam, oil pump, F-Body oil pan with Improved Racing baffle, and LS6 valve springs.
Old Feb 22, 2015 | 12:48 PM
kez's Avatar
kez
Cool build good luck keep us posted
By the way the 3.92 diff was from 97-2000 sc400
92-96 has the 4.27 gear set
Old Feb 22, 2015 | 04:42 PM
mooreofit's Avatar
mooreofit
Cool build.im in spring of 45 i drift or try to anyways with the lone star group.i think you are the guy who sold the 1uz to dave for his 86.we should meet up sometime.
Old Feb 23, 2015 | 04:34 AM
RotaSpinna's Avatar
RotaSpinna
So I'll actually have a 3 speed transmission! haha
Old Feb 23, 2015 | 04:36 AM
RotaSpinna's Avatar
RotaSpinna
That's me. Dave is a cool guy. What are you driving? I've seen a couple pictures of SC chassis at events. What color is yours? White?
Old Feb 23, 2015 | 05:10 AM
gerrb's Avatar
gerrb
Super Moderator
You probably are confusing SC300 gearings from SC400. No SC400 came with 4.27 gear set.
92-00 Lexus SC300 auto---- 4.272:1, open, small diff, small flange
92-97 Lexus SC300 5spd---- 4.083:1, open, small diff, small flange
92-96 Lexus SC400 (auto)---- 3.916:1, open* small diff, small flange
1997 Lexus SC400 (auto) after MC but before going to 5AT trans - 3.916:1, open, small diff, BIG flange.
98-00 Lexus SC400 (5AT trans, VVTi)---- 3.266:1, open, small diff, big flange
OP - good luck with the build .
Old Feb 23, 2015 | 07:06 AM
mooreofit's Avatar
mooreofit
Yep,white with the black xxr 526 its usually just me and the red one.i forget the guys handle but he is on these forums i havnt meet him but i spun infront of him one time and he almost hit me. He did a fine job at dodging me.where are you at id like to check out your build.dave said you were in spring.p.s 4.26 gear sucks for the w58 on the freeway at 70mph im at 3k rpms 1st gear only goes to 20mph
Old Feb 23, 2015 | 08:14 AM
mooreofit's Avatar
mooreofit
Also if your mounts are out of the car id like to blue print them so i can make my own.
Clean400
Dec 13, 2017 07:25 AM
Dreamer88
Sep 12, 2014 12:05 PM
toymotaguy
May 26, 2013 09:07 AM
93SC400Blk
Oct 22, 2009 06:31 AM
ERicincal
Apr 11, 2002 12:01 PM
