Errrrrrrr noise(help all gurus)
Old Dec 29, 2014 | 09:27 PM
spurge's Avatar
spurge
Registered User
Default Errrrrrrr noise(help all gurus)
I have a 97 sc300, when I turn the steering wheel left or right I am hearing a errrrrrrrrr sound coming from the belt where the fan is and a concentrated vibration on the steering wheel. The Power steering reservoir is full and I see no leaks. What could be the issue here
Old Dec 29, 2014 | 11:32 PM
ArkLaTexSC's Avatar
ArkLaTexSC
Steering rack would be my first guess, though I haven't a clue what's wrong with it.
Old Dec 30, 2014 | 08:17 AM
oldManTan's Avatar
oldManTan
while the car is running open the PS reservoir and see if it's bubbling. could just need a flush or ATF instead of regular power steering fluid that you might have. our cars require ATF for the power steering, not regular power steering fluid. i had a horrible whining and screeching and all i did was flush some of the fluid, not even all of it cz i didnt have time, added some toyota ATF and let it bubble out. no more problems.
Old Dec 30, 2014 | 12:21 PM
spurge's Avatar
spurge
Registered User
I will do the test. Now if there is
No bubbling. What to do there after. I need worse case scenario here
Old Dec 30, 2014 | 03:31 PM
t2d2's Avatar
t2d2
I would guess oldManTan is right. That sounds like the noise it would make for a day or two after replacing the rack & pinion, and probably after flushing the fluid. It sounds awful, but it works itself out pretty quickly the more you engage the power steering, i.e. turning, while driving.
Dylroberts
Sep 24, 2015 11:46 AM
Jfg kevin
Dec 19, 2009 12:20 PM
SC_Edgar
Jul 31, 2009 12:19 PM
PecosBill
Feb 6, 2009 08:42 PM
suprandsc
Sep 4, 2006 10:54 AM
