Tacho problems SC400
Old Nov 3, 2014 | 10:25 AM
Robgrob's Avatar
Robgrob
Default Tacho problems SC400
I have a problem with my tacho, it has been this way "forever" according to the 2 previous owners.
The tacho reads about 30% wrong. It idles in 500rpm, and rev limit is 4300 or so.
Its a SC400. Does anyone know of any fixes, or should I just get a 5" on the dash?
Old Nov 3, 2014 | 01:19 PM
Ozzzzy's Avatar
Ozzzzy
Default Swap
I had a problem with my tach, I just went to the junkyard, pulled another cluster and then swapped the tach motors. Worked perfect after that.
Old Nov 3, 2014 | 01:29 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
It is likely your stepper motor inside the cluster for the tach. Service will cost you around $100 to replace the motor.
Old Nov 4, 2014 | 02:08 PM
Robgrob's Avatar
Robgrob
Thanks. Ill look into that stepper motor!
Old Nov 7, 2014 | 03:16 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Depending on if you have a 5 speed or auto you have either one capacitor or two controlling the tach reading on the tach motor. If one of the caps starts to dry up it can give incorrect readings. You can search my user id for a thread I did on the tach and speedo.
Ozzzzy
Dec 2, 2018 07:21 AM
Holger
Jun 8, 2013 10:46 AM
Maik04
Apr 14, 2012 07:24 AM
TroySC300
SC400 / 300 Classifieds
13
Nov 2, 2010 06:47 AM
attis
Apr 25, 2006 08:59 PM
