strange tachometer
Old Jun 7, 2013 | 04:12 PM
Holger's Avatar
Holger
Default strange tachometer
Hi
I have a little strange problem with my tachometer. it shows a few thousand rpm error.
at idle, the 200 rpm and at full throttle it stops at about 4500 rpm, but the engine going until the rev limiter as usual
Old Jun 7, 2013 | 09:10 PM
Brianmoss's Avatar
Brianmoss
Just try tapping it, if that doesn't work try cleaning your connections
Old Jun 7, 2013 | 09:18 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I second that.. prolly the motor is going out. I had a SC400 that had that problem. Swapped the motor and good to go. Also check to see if the needle is fully secured and not on too tight. Cant be but a few things here.
Old Jun 8, 2013 | 08:24 AM
Holger's Avatar
Holger
what motor?
Old Jun 8, 2013 | 09:31 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
The motor in the cluster that moves the needle.
Old Jun 8, 2013 | 10:46 AM
Brianmoss's Avatar
Brianmoss
I have a spare cluster if you want it.
Ozzzzy
Dec 2, 2018 07:21 AM
Robgrob
Nov 7, 2014 03:16 AM
Maik04
Apr 14, 2012 07:24 AM
socalturbo
Jan 2, 2010 12:27 PM
Ali SC3
Jun 16, 2009 08:01 PM
