Cluster lights?
Today I drove it to measure a couple of jobs that I need to bid. I was running at about 60mph, then throttled back for a turn, and everything shut down. I coasted to a stop, popped the hood, and found out that my positive battery lead had come off the post. I put it back together, and she fired up, but suddenly my dash is even darker than it was. All of the backlighting on the right side of the cluster is now dark, suddenly. Does that make sense?
You might check the gauge illumination adjuster to make sure it didn't get rotated unknowingly.
I wouldn't think there is a fuse(s) that affects just some of the gauge cluster bulbs? My concern would be, what else might get damaged at the same time as bulbs? Hopefully, there are fuses protecting most such sensitive equipment.
Definitely check the illumination ****. I and others have been confused by lighting issues that turned out to just be the **** getting disturbed somehow.
