Poor Fuel Efficiency
Old Feb 25, 2003 | 10:56 PM
mjames08's Avatar
mjames08
Default Bad MPG
I am only getting about 16-17 miles per gallon in my 93 SC400 w/116,000 miles. Is this typical? What could be causing such a low gas mileage?
...okay I did a search and it seems like a lot of people are getting the same results as me.. but a lot are also getting better.. any ideas?
Old Feb 25, 2003 | 11:07 PM
strongsail's Avatar
strongsail
I have a '93 SC4 with 107K, I get 18 town, 21 highway, but I'm old. Try taking your foot off the gas now and then and everything will be fine...
Old Feb 25, 2003 | 11:18 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
make sure you arent gong by $ amount. i was confused at a drop in mile per dollar until i remembered gas went up 20 cents recently.
Old Feb 26, 2003 | 08:03 AM
TurboSC's Avatar
TurboSC
Your O2 sensor could be damaged which would make you lose gas mileage. But it all depends on your driving style just like said above, if you are always flooring it you will have worse gas mileage.
Old Feb 26, 2003 | 08:17 AM
bizzy928's Avatar
bizzy928
You should remove your EFI fuse overnight. Your MPG will go back to factory "efficient" specs.
Old Feb 26, 2003 | 09:23 AM
bberisford's Avatar
bberisford
Question MPG computer is optimistic
My mpg hand calculations (22.5 avg over two tank fulls) are 2 mpg lower than the computer (24.5 mpg).
Any way to adjust the the computer -- or just live with it?
Thanks for the help !!
Old Feb 26, 2003 | 10:24 AM
mjames08's Avatar
mjames08
Thanks for the replies everyone.. I will try the EFI fuse and have the O2 sensor checked out, but first I will watch how I drive. I don't think that I drive fast, but maybe that's because I am used to it.
Old Feb 26, 2003 | 10:58 AM
EmeraldLexuSC3's Avatar
EmeraldLexuSC3
Post Engine in tune
When was the last time you had a tune-up?
Check air filter, gas filter, plugs etc. This will contribute to better gas milage. Also take in consideration how often you utilize your O.D. and ECT power buttons as well as the lead in your foot!
Old Feb 26, 2003 | 02:10 PM
THE_CEO's Avatar
THE_CEO
Default mjames08 !!!
ok this has been discussed several times, first fill your tank to the max and see how many miles you can drive before your orange light comes on...im getting about 350 miles with city driving before the light comes on...you may be getting better gass mileage than you think...the best i have gotten before my light comes on is 397...a combination of highway and city...so you could be fine but use that as a self check and the do a search for the gas mileage...
Old Feb 26, 2003 | 03:25 PM
Camshaft's Avatar
Camshaft
I have gotten over 400 several times for highway driving. I get around 300 in the city but thats mostly on the floor. Several members get over 400 consistantly. I pulled 447 on the way to Memphis without the AC and I only had one race with a Rousch GT.
Old Feb 26, 2003 | 07:37 PM
DaizenLex's Avatar
DaizenLex
hmmm i get around 200 for 15 gallons, i have 134,000 miles should i do a tune up any suggestions?
Old Feb 26, 2003 | 08:26 PM
THE_CEO's Avatar
THE_CEO
200!!!...what kinda mods do you have on your car?...and when (at how many miles) does the orange light come on?
Old Feb 27, 2003 | 07:41 PM
DaizenLex's Avatar
DaizenLex
At 235 my light comes on thats city driving, i think the car might need a tune up bad, i use checvron techron fi cleaner but mileage still stays the same any recommendation?
Old Feb 28, 2003 | 08:02 AM
THE_CEO's Avatar
THE_CEO
yeah you need to do something to that car your getting lamborghini gas mileage...wow! did you already try to reset the ECU?...see if that helps...
Old Feb 28, 2003 | 09:31 AM
T0ked's Avatar
T0ked
Yup, that's pretty bad. I usually get abouy 15-17mpg city, but I admit that I have a lead foot. I too have gotten over 400 miles from a tank full every now and then. My mpg always drop when driving in NYC, basically the race of your life to the next red light... Reset your ECU and see what happens.
