The uneven drop problem
Old Sep 2, 2014 | 04:45 PM
  #31
Albatross's Avatar
Albatross
The rear spacer would be machined from T6 aluminum and the front would be a modified OEM mount with 2 new longer grade 8 equivalent bolts. So far this is the least expensive way to get it done.
If I got 5 people on board I could do it for $95 for the whole kit. Less than that and my cost for making the rear spacer goes up a pretty good chunk so for a one off it might be closer to like $130.
Old Sep 8, 2014 | 01:20 PM
  #32
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
don't let this turn into a group buy unless you want to become a vendor. there are a bunch of rules regarding that stuff. if you want to sell some extra in the classifieds then that can be different, but I think people can figure out how to make a spacer and grab some bolts from the info provided.
Old Sep 9, 2014 | 05:29 AM
  #33
Albatross's Avatar
Albatross
I was only letting people get in on my order but okay.
Anybody: PM me if you want one of my spacers.
Old Dec 28, 2014 | 12:51 AM
  #34
jayydm's Avatar
jayydm
does this happen with all the available lowering springs or only the supra spring setup
Old Dec 28, 2014 | 07:52 AM
  #35
Albatross's Avatar
Albatross
All, it is just more noticeable the lower you go. I added 1/4" spacers up front and 1/8" in the rear to get the suspension travel I want (and perfect ride height for me). The car rides and handles great now, I hated the harshness of coilovers.
Old Apr 11, 2015 | 02:41 PM
  #36
Dobbin's Avatar
Dobbin
This is a pretty weird problem
Old Apr 14, 2015 | 10:11 AM
  #37
choover's Avatar
choover
Default one side
I am only having this problem on my driver side.will this gel. Can I order just 1or has to be 2
Old Apr 14, 2015 | 10:14 AM
  #38
choover's Avatar
choover
Default change
Sorry.I just read back.ok..How Do I order a set
Old Aug 2, 2015 | 09:22 AM
  #39
sc4hunnit's Avatar
sc4hunnit
I thought i was the only one it happened to. Ill most likely be doing coilovers and the like to my suspension. I have KYB and Tanabe nf210's, which ride great and after settling, look great. Those will be up for sale soon.
Old Dec 16, 2016 | 09:11 AM
  #40
Equalizir's Avatar
Equalizir
So I put Espelir springs on my car and I too have noticed my right side is higher t han my left. I actually really like how low my driver side is. So this fix will raise my driver side or lower the passenger side? If its gonna raise my driver side then I'll just get coilovers. Should've gone that route to begin with
Old Dec 16, 2016 | 09:51 AM
  #41
Blkexcoupe's Avatar
Blkexcoupe
It'll raise your driver side. Every time I've installed coilovers on my SC the driverside is always about 10mm higher than the passenger side to make the front even.
Old Jan 9, 2017 | 03:55 AM
  #42
abigailcar's Avatar
abigailcar
Had the same problem and have done by professionals and even advice from them. I scanned around and found this post. So sad its late and should I be the one changing it. But thanks for this post for knowledge.
Old Mar 18, 2017 | 07:51 AM
  #43
RXRodger's Avatar
RXRodger
One observation looking through this thread is most seem to not catch that it is not just the height that needs to be adjusted, but boergy seems to have pointed out the geometry is different as well. It appears he measured the shock needs to be moved out 5mm to create the same geometry side to side. This being the case, it would change the "motion ratio" ever so slightly. I think of it this way, what would be effected by this geometry, like a fulcrum, if you push at a point further out on the lever arm from the rotation point it doesn't take as much force to get the same result at the end (tire patch). Really interesting observation.
Edit: I did this today. I slotted per Boergy's dimensions. Rather than weld washers on I made a shim plate with hole diameters same as the bolt so it could not slip. I had to grind the edges of the washers so they would fit the contour of the countersink area.
Bare control arm
Shim plate
Shock bracket slotted
Washer ground to fit that i ended up not using, used originals and ground those to fit
Final position torqued at 40 ft-lbs
RetroGamerJP
RC F (2015-present)
47
Feb 11, 2015 07:07 PM
SSmith
Jan 10, 2013 02:16 PM
fosterjd24
Maintenance
Apr 22, 2009 10:49 AM
alfa2600
May 10, 2008 01:14 AM
