What are these sensors
Old Jan 24, 2014 | 04:46 PM
grumpi300's Avatar
grumpi300
Default What are these sensors
Hey guys. I have a 92 n/a Sc300. I just removed the intake and need some help with knowing which sensor is what.
I'm guessing two of them are knock sensors cause I know ours has 2. But Idk which ones they are. I'll post these pics up in a second.
Old Jan 24, 2014 | 04:51 PM
grumpi300's Avatar
grumpi300
This one is on top of the starter.
Old Jan 24, 2014 | 04:55 PM
grumpi300's Avatar
grumpi300
This one is inside the oil pan under the starter so I'm guessing it's an oil level or pressure sensor sensor?
gtsfire's Avatar
gtsfire
That's a knock sensor.
Edit. The first pic.
Old Jan 24, 2014 | 04:56 PM
grumpi300's Avatar
grumpi300
I'm guessing one of these is a coolant temp sensor but in which one. I wanna know what each one is.
Old Jan 24, 2014 | 04:58 PM
grumpi300's Avatar
grumpi300
Last but not least is this sucker here. Hard to even unplug. It's right behind the ac compressor.
Old Jan 24, 2014 | 04:59 PM
grumpi300's Avatar
grumpi300
Thanks gtsfire. I thought so. I'm guessing both that look the same are knock sensors? One towards the front of the engine and this one on top of the starter.
Old Jan 24, 2014 | 06:27 PM
CrispyST3's Avatar
CrispyST3
the green one is coolant temp
the other one with the orange base is you coolant temp gauge sender unit
Old Jan 24, 2014 | 06:45 PM
grumpi300's Avatar
grumpi300
So the one on the right is for the guages on the cluster and the other on the far left is for the ecu?
Old Jan 25, 2014 | 07:53 PM
grumpi300's Avatar
grumpi300
Anything else?
Old Jan 26, 2014 | 07:21 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
That's it I think.
dadude
Aug 6, 2012 10:50 AM
Carib
Mar 22, 2006 07:26 AM
RUDENESS
Aug 25, 2004 12:52 PM
