1jzgte issues
Old Dec 27, 2013 | 03:44 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
Default 1jzgte issues
Whats up guys i have a 98 sc300 1jz swap automatic, the turbos are rebuilt steel wheels, boost cut defender, wally in the tank, bfmic, uego wideband, mbc, stock 1jz comp
If i boost anything past 13lbs, it hits boost cut and the uego pegs 10.0? but normal cruise is 14.2 - 15.8. any ideas? i have an emb and an avc-r that are just sitting
Old Dec 27, 2013 | 03:48 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
that seems way to rich to me
Old Dec 27, 2013 | 05:43 PM
INTIMAZY's Avatar
INTIMAZY
Ya mean at boost cut it hits A/F of 10? Sounds normal...
Old Dec 27, 2013 | 06:45 PM
soarer479's Avatar
soarer479
What plugs are u running and what gap
Old Dec 27, 2013 | 08:42 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
no it will run at 10.0 but over 13 lbs it will boost cut bad i cant full throttle it at all,
im goin to check plugs n gap in the morning
Old Jan 3, 2014 | 07:10 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
Ok sorry for the delay I had a bad vc leak so had to fix that first, I have ngk 7 plugs n they were gapped at 28 I gapped down to 26, still same issue, coils are fine boots got cleaned out n seemed fine. This is my first 1jz I had a 2jz jdm swap in an is but it was obd2. HAPPY NEW YEAR to every one
Old Jan 4, 2014 | 06:45 AM
Vrank's Avatar
Vrank
Maybe your boost gauge sucks? Everything seems normal aside from the 13psi cut. You shoulda realized this was normal if you had a gte swapped 2j. They do the same thing as far as fueling at wot stock. Vvti or not.
Old Jan 4, 2014 | 06:53 AM
RyanV's Avatar
RyanV
hey vrank i got a problem with my turbo...when i floor it my car peels out?
Old Jan 4, 2014 | 12:21 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
Never had a boost cut issue on the 2jz even when I did the single turbo with a profec b 2 at 18 lbs never had this issue, n dont the 2jzs boost stock alot higher
Old Jan 4, 2014 | 03:52 PM
INTIMAZY's Avatar
INTIMAZY
A 1JZ boost cuts around ~ 13psi. You have something that SHOULD defend against that. I'm gonna bet its set too high. With just an SAFC and 550s I was able to skew the MAP voltage so that the ECU never 'saw' boost cut up past 20psi.
Old Jan 5, 2014 | 02:50 PM
BoOsT-CrAz's Avatar
BoOsT-CrAz
ok i have an AVCR but i also have an emanage blue that i have sitting around and thought about putting it in since i have it? and get an E0-1 to control boost aswell as the emb?
shonuff53
Apr 6, 2011 07:39 AM
94_soarer
Dec 8, 2010 06:54 PM
trevor10
Jul 23, 2010 07:02 PM
soardrft
Jun 3, 2009 07:17 AM
mattsmall
Jul 31, 2007 08:37 PM
