1jz WOT sputter
Subscribe
May 28, 2009 | 07:10 AM
i have had my 1jz for about 8 years. same stock turbos not blown, same blitz exhaust, and intake. i just recently did a tune up with new plugs and oils and also added a 3' downpipe and eliminated the cat. since i installed the downpipe, it seems like when i try to floor it the car sputters. rather it be in 1st or 5th i get the sputter. can anyone let me know what is going on?
Reply 0
May 28, 2009 | 07:23 AM
What's your boost at WOT. You might be hitting boost cut with the 3" DP.
Reply 0
May 28, 2009 | 07:34 AM
no guages in the car so i have no clue. but if that is the case does the afc take care of that?
Reply 0
May 28, 2009 | 11:19 AM
You need a boost controller, fcc or bcc. By freeing up your exhaust with the DP you in turn raised boost pressure
Reply 0
May 29, 2009 | 03:42 AM
Either what LexusFTW has said or lower the gap of the spark plug from 1.1mm to 1.0mm then 0.9mm then 0.8mm (NO LOWER) until it stops missing at WOT.
Its a common fix because when you are chasing dyno numbers the first thing that needs upgrading is the ign coils.
Reply 0
Jun 3, 2009 | 07:17 AM
i have hks iridium spark plugs. i will try gaping the old plugs that were in there to see if it works
Reply 0
Subscribe
