Car dies after plugging in MAF
Old Oct 8, 2013 | 11:38 AM
baddis es's Avatar
baddis es
Default Car dies after plugging in MAF
friend of mine has a factory 92 5spd...it was sitting for a couple months and when we went to start it up, the car would run/idle without the MAF connected but once connected, the car dies out completely.
he's rebuilt the ECU and has tried 2 different MAF's, all of which brought no luck
any ideas/suggestions on what could be happening/causing this?
Old Oct 8, 2013 | 12:23 PM
mikef's Avatar
mikef
try the 12v ecu pump mod
Old Oct 8, 2013 | 01:04 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Moved to performance and maintenance section.
no don't try the 12v fuel pump mod, that has nothing to do with the maf. if it is running at all you have spark and fuel, it is clearly a sensor or electronics issue if it clears up when disconnecting the maf.
This really does point to a faulty maf or some other sensor. did the other maf you tried work before or do you guys not know. can't rule out a bad maf if you are not sure the replacement works.
Old Oct 8, 2013 | 02:47 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Use an MAF that you're sure is in working condition and swap it in to see if that makes a difference.
Old Oct 9, 2013 | 06:20 AM
baddis es's Avatar
baddis es
i'm unsure the condition of the other MAFs when we replaced them with the original, he had obtained them somehow and we just plugged them in trying to see if that was theissue. all three (inlcuding the factory MAF) gave the same result, and the coincidence as to how likely that could be for all of them kind of swayed us away from that
i'll see if we can get someone local with a 92 SC300 to swing by and test theirs. thx!
Old Nov 13, 2013 | 12:30 PM
MongooseGA's Avatar
MongooseGA
What ended up being the problem here? I'm having a similar issue. MAF plugged in, the car runs like ****. Sputters down low and clears up in the mid range to pull hard. Replaced it with a MAF from aliga and I have the exact same problem.
The only time a CEL shows up is when the MAF is unplugged, and its accompanied by the TRAC light. No lights at all when the MAF is plugged in and it's tricky to diagnose.
Old Nov 13, 2013 | 04:34 PM
SC4Paulo's Avatar
SC4Paulo
look for a good MAF that you know will work and try again, there is a high chance that all 3 MAF's you guys got could be bad.
Old Nov 25, 2013 | 10:09 AM
MongooseGA's Avatar
MongooseGA
I swapped my second MAF with a known good unit from a neighbor. The car will run fine from down low for a minute or two, and then runs terribly afterwards. Same thing; MAF plugged in and it sputters and feels like a misfire until about 2,100 RPM. Afterwards she feel beautiful.
MAF unplugged and despite the CEL and TRAC lights being on, and getting horrible gas mileage, she runs perfectly.
Anything in the MAF wiring that could be wrong? WHen I swapped the parts I only changed out the sensor itself, not the metal housing. Is there any reason the metal housing would cause an issue with the computer reading the MAF?
MattJO
GX - 1st Gen (2003-2009)
Apr 4, 2017 11:18 AM
Allaretake
Jun 3, 2010 02:36 PM
jrbury3
Feb 7, 2009 05:43 PM
Dx3
Apr 28, 2006 03:54 PM
