SC300 won't crank
Old Oct 2, 2013 | 09:53 AM
iBernie's Avatar
iBernie
Default SC300 won't crank
So I took out my gte block to build her up and swapped my buddy's na into my car. His motor was working right before we pulled it out to put into mine. Had other problems but solved them.
Only issue I am having right now is it won't crank at all.
I did however jump starter relay and she cranked and started right up. Replaced relay with the boxes full if new ones but still won't crank by the key.
I doubt that all my relays are bad so I believe something to do with the ignition perhaps?
Any input guys and gals? Thanks in advance.
Old Oct 2, 2013 | 11:45 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Welcome to CL, please post in the proper sub-forum. engine related questions go in performance and maintenance. Your thread is being moved there.
Old Oct 2, 2013 | 05:04 PM
soarer13oy's Avatar
soarer13oy
check wiring at the body plugs. Your not getting a signal to the starter relay.
Old Oct 3, 2013 | 12:00 PM
Vrank's Avatar
Vrank
Neutral start switch wiring
Old Oct 3, 2013 | 12:01 PM
Vrank's Avatar
Vrank
Was your car factory auto? Is the donor engine factory auto? Is your car currently auto? Hard to help when you don't list your setup.
Old Oct 7, 2013 | 07:04 AM
iBernie's Avatar
iBernie
Sorry about bland info. Factory 5speed. Soarer13oy got it. Car is a 95. Motor from 97, so I had to repin a body plug. Thanks and sorry again for not enough info.
prestony7
Aug 13, 2016 02:57 PM
davvv
Aug 27, 2014 04:54 PM
soarerdd
May 7, 2011 04:53 PM
RDKUT
Sep 30, 2007 10:29 AM
