Electrical Issue
Old Aug 14, 2013 | 06:55 PM
Dx3's Avatar
Dx3
Default Electrical Issue
Car: 97 SC300, lowered.
Issues: I drove the car yesterday for the first time in about 2 weeks. I noticed all the back lights on the cluster, and all the needle lights are not lighting up. The gear light indicator on cluster works, as do all the lights along the bottom of the cluster. Not sure if it's related, but all of a sudden my tach isn't working. Other needles move (except tach), they just don't light up.
Again, not sure if it's related, but recently I can't get my alarm (aftermarket) to lock my car. It will unlock and do everything else, just won't arm. The key fob has been beeping like there's an issue, but the screen is bled on the fob so I can't see what the issue is. I tried replacing the battery and it didn't help.
Diagnostics: I checked the wiring in drivers wheel well to see if I needed a harness relocation, but it looks like previous owner already took care of this. So, I know it hasn't rubbed through and damaged any wires.
I tried turning the brightness dial on gauge cluster and it didn't help. All backlights and needles worked fine prior to this.
All fuses look ok, although I did not check with a voltmeter.
Ideas?
Old Aug 15, 2013 | 07:09 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Originally Posted by Dx3
Car:
ADD TO THAT:
AND I'M TOTALLY TRUSTING HIS WORK AND THAT THERE IS NO CORROSION AT ALL ON ANY OF THE CONNECTIONS THERE AT THE POINT WHERE WATER SLINGS MOST INTO ON THE ENTIRE CAR UNDERSIDE AT THE WHEEL
....................Eh?
Old Aug 15, 2013 | 02:54 PM
Dx3's Avatar
Dx3
Originally Posted by O. L. T.
ADD TO THAT:
I did not see any connectors in the wheel well... Maybe I need to go back outside.
Jonny
Old Aug 16, 2013 | 02:01 AM
soarer13oy's Avatar
soarer13oy
Have you checked the fuses? I think it was the fuse labeled Dome.
Old Aug 16, 2013 | 10:31 AM
Dx3's Avatar
Dx3
I'll check it again tonight - thanks man
Old Aug 16, 2013 | 06:38 PM
Dx3's Avatar
Dx3
Thankfully just a fuse... not the dome one though but got me started on fuses again. Thanks guys!
Old Aug 16, 2013 | 07:24 PM
soarer13oy's Avatar
soarer13oy
glad you got it to work
Deedorah
Jun 28, 2019 08:55 PM
JGWentwrth
Sep 17, 2018 04:30 PM
ghoul
May 5, 2015 10:20 AM
sedge11
Sep 15, 2010 11:42 PM
j stuff
17
Jan 22, 2008 06:04 PM
