Still idling problems please read!
Old Aug 9, 2013 | 01:20 PM
millertime's Avatar
millertime
Default Still idling problems please read!
That's it!
I switch my computer with another guy on here, so I could put my car back to stock.
I had a Jet.t chipped ecu. He had a stock
I'm almost 100% sure that he shafted me.
After about 4 days of having the new computer the idle started going down and down, and now i had to screw the throttle stop out so that its like I'm pushing the gas a little,
Afm. Perfect,
Iac, replaced and still same symptoms
Dropped exhaust for maybe clog ,nope
Spark plugs? No
Tps? Perfect
Is there anything else that will cause a 1uzfe to not idle?
And is there anybody in the pittsburgh area that would let me borrow their ecu for an afternoon
Or anybody local who would have suggestions?
Thanks
Sean
412-969-6389
Old Aug 9, 2013 | 03:20 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Check your vacuum lines.
Old Aug 9, 2013 | 03:22 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
oh yeah, clean your intake throttle body. Any black residual will cause a little problem
Old Aug 9, 2013 | 03:27 PM
millertime's Avatar
millertime
Which ones and what I'm I seeing what they do?
Should I check for suction?
Old Aug 9, 2013 | 03:40 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Yes check for suction or cracks. If you think they need to be replaced, then replace them. Its cheap insurance. Check all of them. There is two that goes under the actual intake. Spray carb cleaner on the motor while its running, and see if the idle raises or lowers, then go from there. Clean the intake of the throttle body with carb cleaner. Make sure to use a new gasket.
Old Aug 9, 2013 | 06:03 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Use a smoke machine and run a smoke test to look for air leaks in the manifold and vacuum lines. O2 sensors are a common come and go item that the SC eats for breakfast. You might wanna check those for voltage. Make sure your gasoline is clean by running a tube of injector cleaner throught the tank. In fact, do that just for grins. It probably needs it if it hasn't been done in a while.
Old Aug 10, 2013 | 12:38 AM
wth98sc's Avatar
wth98sc
or just use a cigarette :P
Old Aug 11, 2013 | 11:15 AM
millertime's Avatar
millertime
I'm confused on the smoke test idea, how do u test if a vacuumed leak is it? I really want to try a new computer. I'm so worked up about this car
Old Aug 11, 2013 | 03:57 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Smoke is done by a mechanic who has the machine. It is injected in the motor and where the smoke appears thats the leak. Easy and eliminates any probability.
Old Aug 12, 2013 | 05:51 AM
millertime's Avatar
millertime
Oh so through the intake tube,
Wish I knew a mechanic who had a smoke machine
2jzforlife
Nov 14, 2012 08:12 PM
ScNoobie
Apr 28, 2009 09:46 AM
NoLongerA13bFan
Jan 2, 2007 11:52 AM
TMaxxTim
Jan 21, 2006 08:53 AM
