what is this??
Old Aug 7, 2013 | 08:31 AM
mikef's Avatar
mikef
Default what is this??
I been having idling problems that spikes up and down when i rev the engine.. sometimes it almost stalls out.
I was unplugging devices to see if it makes a differents and the only thing that stop the low dipping in RPM was this. Can anyone help me what this is. thanks
Old Aug 7, 2013 | 08:40 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Its the TPS. Throttle Position Sensor.
Old Aug 7, 2013 | 08:41 AM
mikef's Avatar
mikef
Ok thanks, do you think that would cause the low rpm spikes?
Old Aug 7, 2013 | 08:45 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Absolutely. I would check the resistance and see if it is within specs for starters. If it is, then clean the throttle body and butterfly on both sides. Check for vacuum leaks, and your IACV (Idle Air Control Valve).
Have you tried to loosen this and move it after the symptoms started? Or have you left it alone?
Old Aug 7, 2013 | 08:47 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Like Mark said, the TPS. If your idle is spiking and you suspect your TPS, it might be a good idea to set it to spec. There are a couple threads on that too.
Old Aug 7, 2013 | 08:56 AM
mikef's Avatar
mikef
Yeah I tried to loosen it and move it around but it didnt make a differents, I tried to take off the IACV but the screws that hold it on are really tight,
Im not sure how to get it off yet, I did unplug it and the revving was going up and down over and over so I plugged it back in and tried that TPS and it stopped the weird dips,
whats weird is that when I turn on the ac it really dips down almost stalled
Im going to clean The TPS because i know for sure I can get it off
I cleaned the throttle body and it was super clean already
Old Aug 7, 2013 | 10:26 AM
BiGEZ's Avatar
BiGEZ
Might sound weird but it could be your oxygen sensors. I had the same issue after cleaning my throttle body
Replaced the oxygen sensors and the car ran perfectly. You might want to double check your vac line and
connections. Did you replaced the throttle body gaskets when you reinstalled it?
Old Aug 7, 2013 | 10:44 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
o2 sensors is actually what fixed my SC when it was having issues like this...not really wierd.
Old Aug 7, 2013 | 12:21 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If you believe it is something further, then pull the codes and see what it is. I wouldnt throw things at the car, unless you can narrow it down.
erichuang
Sep 17, 2024 10:07 AM
KTGS300
Jun 10, 2018 04:05 PM
Bloke
Apr 18, 2018 06:36 PM
ankurdave
Mar 13, 2017 08:20 PM
kevinsc300
May 6, 2012 08:30 PM
