soarer r154
Old Jun 27, 2013 | 11:07 PM
ayooaaron's Avatar
ayooaaron
Default soarer r154
Hey guys im doing engine/tranny removal. My main question here right now is how do i remove the driveshaft from the soarer r154 (newbie here. First swap) do i remove the middle driveshaft mount and the bolts connecting the front and rear drive shaft?
Old Jun 27, 2013 | 11:43 PM
95SC3T's Avatar
95SC3T
I would unbolt driveshaft from rear end and then unbolt the carrier bearing from chassis. Slide forward half inch if u can. Drop the rear part down and then slide the driveshaft towards back of car and out of trans.
Old Jun 27, 2013 | 11:50 PM
95SC3T's Avatar
95SC3T
From. The looks of the second pic you can slide the driveshaft in to the trans enough to get the rear part of the driveshaft out of the rear end yolk.
Old Jun 28, 2013 | 12:32 AM
ayooaaron's Avatar
ayooaaron
ok so i what i do is remove the mid driveshaft mount and remove the rer bolts of the driveshaft and slide it out the tranny?
Old Jun 28, 2013 | 01:13 AM
jwin's Avatar
jwin
Mark your driveshaft so you can put it back in the correct position then you undo the 4 bolts at the mid mount that hold the front shaft to the rear shaft. After that you undo the two bolts that hold the mid mount and that will separate your driveshaft and it will allow you to pull the front drive shaft out of the transmission. Reinstall the two bolts that hold the mid mount until you are ready to put the front driveshaft back in. Make sure you mark the driveshaft because it is balanced and you don't want to put it back in any which way because it could cause a unbalanced.
Old Jun 28, 2013 | 01:18 AM
ayooaaron's Avatar
ayooaaron
ahh good idea! i wil def. mark it
Old Jun 28, 2013 | 01:32 AM
95SC3T's Avatar
95SC3T
I have always just removed the whole drive shaft.
Old Jun 28, 2013 | 04:27 AM
lexforlife's Avatar
lexforlife
be sure and drain tranny first or when you slide it out from tailshaft , gear oil will run all over the place and it stinks , i have a cut front piece that i use so when i pull out the orig one i stick the cut one in and plug it up , then again i work on alot of these cars
Old Jun 29, 2013 | 06:18 AM
Vrank's Avatar
Vrank
Sorry but this is horrible advice. It's only 5 bolts to pull the whole shaft, and it's quicker/easier that way.
But in all honesty, OP you shouldn't even be doing this. Don't blame it on "first swap". This is extremely basic mechanical type stuff. Common sense type stuff. If you can't pull this part off without someone holding your hand there's gonna be problems. I highly recommend you purchase a service manual for your car, but then again I don't think it will do you good as you will need to make some inferences and figure stuff out that's slightly different from factory.
Old Jun 29, 2013 | 07:04 PM
ayooaaron's Avatar
ayooaaron
i got it, turned out to be i just needed some simple wd-40/pb blaster, came right off.
2JTsc300
May 31, 2013 05:23 AM
snakehead
May 23, 2012 07:32 AM
want sc300
Jan 15, 2010 06:21 AM
platinumJZZ31
Feb 4, 2008 03:20 PM
