Power steering noise
Old Jun 6, 2013 | 12:45 PM
Holger's Avatar
Holger
Default Power steering noise
1992 sc400
I just replaced the pressure hose to the power steering pump, but after I changed the hose it came a noise from the pump that was not there before I switched hose. bleed the system many times, but the noise is not completely gone. someone who can help me?
thank you in advance
Old Jun 6, 2013 | 01:15 PM
Bleak's Avatar
Bleak
record the noise. Is it more of a squeel, or a knocking noise? Does it only happen when you turn the wheel, or during idle? Video or audio would help here.
Old Jun 6, 2013 | 02:40 PM
Holger's Avatar
Holger
sound comes as soon as I turn the steering wheel. sounds the same as when there is too little fluid. I am a mechanic myself, have tried to bleed many times and changed the oil 3 times so it's like new. annoying since the sound was not there before I switched hose: (
Old Jun 6, 2013 | 03:09 PM
blk&blu*j's Avatar
blk&blu*j
There is a real fine screen on the inside of the reservoir at the bottom were the supply line is we usually just punch them out with a screw driver.
Old Jun 7, 2013 | 07:15 AM
Holger's Avatar
Holger
ok. thank you
is there any DIY With Pictures how to do this?
Old Jun 7, 2013 | 04:00 PM
Holger's Avatar
Holger
there has also been a new leak from the vacum valve, located in the pressure line, I wonder if it can be removed and then weld up the hole where the valve is?
Old Jun 8, 2013 | 09:41 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If that doesnt fix it, then I would try to bleed your car with it not running. I have always found this best method, if you havent already done so. I agree with Roger, poke a hole in the screen with a screwdriver. Good luck.
Old Jun 8, 2013 | 12:44 PM
blk&blu*j's Avatar
blk&blu*j
If you are talking about the 2 vacuum lines that go to the steering pump where the banjoed pressure line is, leave the one that comes off the throttle body and plug the other 1 so you dont have a leak the only thing that one does is for the speed sensing control!
Old Jun 8, 2013 | 02:53 PM
Holger's Avatar
Holger
ok. thank you for answering. i wil block the vacum lines and remove the valve on the banjo tomorrow. i wil try bleeding it without the engine running.
Old Jun 8, 2013 | 03:03 PM
blk&blu*j's Avatar
blk&blu*j
Leave the banjo bolt just put a plug on the vacuum line that comes from the manifold. block the line and the valve.
Leave the vacuum line from the throttle body to the 1 way valve.
Old Jun 8, 2013 | 03:23 PM
blk&blu*j's Avatar
blk&blu*j
Old Jun 8, 2013 | 03:25 PM
Holger's Avatar
Holger
The problem is that it leaks out from where you turn in the valve, tried to tighten it even more, but still leaking slightly
Old Jun 10, 2013 | 01:03 PM
Holger's Avatar
Holger
Took out the power steering fluid reservoir, took off the lid and removed everything that was inside, filled the new ATF oil and the sound was completely gone afterwards
thank you!
JOHNBRAY11
RX - 1st Gen (1999-2003)
28
Jun 13, 2022 06:54 AM
gs300by
Jan 6, 2016 05:24 PM
zig
Oct 28, 2012 10:45 AM
brianfung
GS - 1st Gen (1993-1997)
Dec 31, 2005 07:02 PM
