Well damn...
Old Jan 8, 2010 | 08:54 PM
chwES300's Avatar
chwES300
Exclamation Well damn...
So I tightened my center caps on my 96' ES300 and its still rattling! I need suggestions bad! Its now nearing the 325,000mi. mark
Old Jan 9, 2010 | 03:22 AM
eyezack87's Avatar
eyezack87
Are you sure its the centercaps to begin with? I know its a common issue but maybe try to remove the chance that it might not be the caps by taking them off and driving it. It wouldn't hurt to try I guess. If it continues to rattle, I'd probably put foam tape around the edge to keep it from touching the rims
Old Jan 9, 2010 | 03:43 AM
tromly's Avatar
tromly
^^^^1, 3M foam tape works great, good luck
Old Jan 9, 2010 | 06:31 PM
chwES300's Avatar
chwES300
nah the caps dont even twist now..they are lockedd in tight so they shouldnt rattle...i dnt think my CV Joints are bad but at 325,000mi anything is possible...could it be struts?
Old Jan 9, 2010 | 11:41 PM
eyezack87's Avatar
eyezack87
Even if they don't twist, the plastic and metal are still touching each other. No matter how tight they seem to be, any vibration will travel between them unless they are one solid piece. Better to eliminate that factor first by removing the caps before deciding other things could be the issue.
Reason being, I solved my rattle issue by doing that right after it started. Thats when I added foam tape
dskendle02
Wheels, Tires & Brakes Forum
Apr 19, 2017 12:56 PM
g2bme
Nov 14, 2013 04:41 PM
hyperb16a
Oct 2, 2006 06:49 AM
Sleepyboi
Sep 22, 2003 01:32 AM
