More suspension options with Supra
My son and I have decided that we are going to go with a Supra setup to lower his SC3. Given many of the reviews here on the site (aside from the Espelir ASD springs for the SC3) we think we are going to go with the Eibach springs and KYB AGX setup. It seems to offer a reasonably nice drop, and the spring/shock combo seem to retain much of the stock ride qualities that are probably closer to stock. Also, it seems that the Supra aftermarket parts are considerably less expensive than that for the SC3, not to mention the broader selection available, since cost and availability are a major consideration. Unless someone can convince us this is NOT the way to go, we are looking for part numbers for both the KYB AGX shocks and Eibach springs. Does Eibach offer any other spring aside from the Pro-Kit? Where do we find "top hats", "shock mounts", and "shock covers" that are often recommended here on CL? And, are these specific to the SC3 or the Supra shock we intend to use?
Sorry for all the questions, but I would prefer to "measure twice and cut once".
i have supra tt KYB struts and Tein springs, and i must say the ride quality is not so good. thats why i'm looking for a comfortable coilover setup this time around on my sc3. I hear Stance retains stock comfort (but they are quite pricey)
I wonder how comfortable the megans are. those are cheap to buy
I highly recommend the Gixxer_Drew Supra/SC suspension as an alternative although it's not designed to go much lower than a couple of inches below stock so as to preserve suspension geometry. It is considerably cheaper than some of the more expensive coilover setups, however.
I don't know if the first page of the thread was updated with this info recently but whether you use the 500/250 version or 600/325 you should use the helper springs outlined in the manual. Early wording says it isn't needed for either of those spring combinations and you can get away without it but you should use the helpers to achieve correct preload upon installation.
Also note that it's not a system intended for more than about 2" of lowering. Maybe 2.5" but that's it. It doesn't change the stock suspension geometry. That said, it's a very good system. For a smoother ride, use the 500/250 version. All versions are very responsive, especially with an upgraded rear sway bar or TT rear sway conversion.
I'd have to look up my receipts but I may have paid just under $1k in total. Maybe it was $900 in total parts.
Here is my short thread covering my install:
https://www.clublexus.com/forums/sc-...-pictures.html
Nice! Looks like i'm going to go with that setup as well. Thanks for the info.
http://www.supraforums.com/forum/sho...pension-thread..
For a mostly street driven sc with the best compromise of performance, comfort, price and ride height, you can't beat oem supra Tt springs and shocks. Any lower and suspension geometry goes to hell. I had bilstein hd supra shocks on ground control control sleeves with 500 up front 250 in the rear. Sold them and went back to oem supra stuff. The bilstein shocks are pretty firm for public roads. Most people on this forum will disagree with me and will do whatever it takes to achieve that hellaflush stanced look with wrong offset wheels at the expense of having any resemblance of a functional suspension setup.
Grimpy
Sep 24, 2002 09:06 AM
