Instrument Cluster
Old Apr 6, 2013 | 09:09 AM
xiaolong's Avatar
xiaolong
Default Instrument Cluster
I have looked in the DIY, the classifieds, and of course, the inter-webs....
I need an instrument cluster, mine's done.
There are tons online on various sites, but does anyone have a recommendation?
Has anyone replaced theirs and where did you get it from?
I hope this is the right place for this thread....
Thanks
Old Apr 6, 2013 | 09:10 AM
xiaolong's Avatar
xiaolong
Lexus wants $850, not interested....
Old Apr 6, 2013 | 09:19 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
There's no such thing as a done instrument cluster. We've talked about this on here for ten years, so the info is out there.
Old Apr 6, 2013 | 11:47 AM
NixusSC's Avatar
NixusSC
what's does 'it's done' exactly entail??
Old Apr 6, 2013 | 12:09 PM
Rwilson's Avatar
Rwilson
Well, if you mean that all of your bulbs burnt out and the needles aren't lighting up, why don't you try lextech.org. (L.L.C) I've been lurking around here for a while and that seems to be the go to place. Heck of a better price than $8xx.xx for a cluster. At least a good starting point for your search. Hope this helped.
Old Apr 6, 2013 | 03:20 PM
xiaolong's Avatar
xiaolong
the speedo, rpm, gas gauges dont work
Old Apr 6, 2013 | 03:33 PM
Tabaka's Avatar
Tabaka
How long have you owned your car? If your needles don't actually move, there's another problem in the cluster. Have you ever removed the cluster and viewed the harness connections?
Old Apr 6, 2013 | 05:48 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Find a used one and switch out the motors. Can be done in about an hour or less. If this is the true problem, or the needles doesn't light up, or both?
Old Apr 6, 2013 | 07:30 PM
ASTERiSK's Avatar
ASTERiSK
I don't see why you don't look for one in a junk yard, if mine works fine I doubt you would have that much trouble finding a decent cluster.
Old Apr 7, 2013 | 01:42 PM
xiaolong's Avatar
xiaolong
everything lights up, needles just don't move
I've been hitting up junk yards, no luck so far. Gonna have to try a little farther away
I haven't looked at the connections, yet. Didnt take it apart. I'll take a look
Thanks everyone, keep on keeping on
Old Apr 8, 2013 | 02:48 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
https://www.clublexus.com/forums/sc-...-and-tach.html
LIke I say, no such thing as a done speedo.
Old Apr 8, 2013 | 08:39 PM
xiaolong's Avatar
xiaolong
yeah I read that one. was gonna try to fix it myself real quick with some motors, but I may just send it to him
thanks
edit: I guess if I send it, it'll be to you! didnt pay attention to your name there
Old Apr 8, 2013 | 09:48 PM
2jznosht's Avatar
2jznosht
Just buy one on eBay and Frankenstein the motors?
Old Oct 22, 2019 | 07:24 AM
lexisaurus's Avatar
lexisaurus
Thanks SpeedKar for this.
I swapped my MPH cluster to a KPH one.
The last ODO I took pre-pulling was 98,004 (miles)
Hex dump shows: 7F FF FF F6 which if I'm following correctly is 99,000. Slight difference is "normal?"
Also I guess the value is not miles or kms then it's just a number so on the replacement KPH ODO I use the same value?
One other question. I am using one of those EZP USB programmers. Should I be able to do this chip in place? I tried wiring in place and could not get a read. I'd prefer not to desolder the "new" unit and thought this was supposed to work. Very good chance of just a bad connection but if this actually can't be done this way would be great to know!
Thx!
Old Oct 23, 2019 | 11:45 AM
KahnBB6's Avatar
KahnBB6
^^ lexisaurus, are you referring to having swapped a Canadian SC300/400 instrument cluster into your U.S. market SC300/400? I haven't been aware of pulling hex values from the SC instrument clusters to have the odometer readout professionally reprogrammed.
Aside, usually a job like that requires you to send in the instrument cluster to a DOT approved repair shop... in the U.S. at least. Not sure what the requirements are in Canada.
