Is this radiator corrosion an immediate problem?
Old Apr 3, 2013 | 02:07 PM
Studiogeek's Avatar
Studiogeek
Question Is this radiator corrosion an immediate problem?
Hi,
I was studying my engine bay and taking pictures today and saw some serious corrosion on the bottom half of my radiator. Is this an immediate problem or not necessarily an issue yet? The car is not running hot. The needle is at 3 o'clock.
If it's an immediate issue, should I go with used or aluminum aftermarket? I want to keep costs down but not pass on an inexpensive upgrade if it will really help.
Attached Thumbnails Is this radiator corrosion an immediate problem?-radiator1.jpg   Is this radiator corrosion an immediate problem?-radbott.jpg
Old Apr 3, 2013 | 02:32 PM
Kris9884's Avatar
Kris9884
It shouldn't be a big deal until, like you stated it starts leaking or the needle shows otherwise. I would def recommend replacing it before you find out the hard way and blow a head gasket. Find one at the junk yard or spend a couple extra dollars and get a koyo/mishimoto and drop it in.
But to answer your question, no, not an immediate issue.
Old Apr 3, 2013 | 02:51 PM
Studiogeek's Avatar
Studiogeek
Thank You!
I'll put it on the "within 2-3 months" list unless needle goes up.
Old Apr 3, 2013 | 03:17 PM
over40driv's Avatar
over40driv
Mine looks the same, is working good.
Old Apr 3, 2013 | 03:46 PM
Studiogeek's Avatar
Studiogeek
Exclamation
AWESOME! Thanks!
Avalos300
Aug 31, 2017 07:37 PM
mr2fast
GX - 1st Gen (2003-2009)
30
Aug 13, 2017 07:28 AM
Ogloc61
GS - 1st Gen (1993-1997)
Sep 16, 2014 12:25 AM
SupraDremr
Aug 14, 2012 02:51 PM
Got2Pbrb
Mar 11, 2009 10:55 PM
