Replacing Leaking Radiator
Old Apr 18, 2010 | 01:26 PM
mr2fast's Avatar
mr2fast
Question Replacing Leaking Radiator
When I was installing my HID's last week I noticed quite a bit of pink goo build up around the drivers side radiator end tank, which as I understand is a fairly common problem. I hadn't noticed a leak around the car but I did grab some toyota red coolant to top the coolant reservoir off. Today I noticed a decent sized puddle, and it now seems to be leaking quite steadily which means I have to replace the radiator asap.
I found this thread: https://www.clublexus.com/forums/gx-...or-change.html which has a nice little write up on the replacement procedure (thanks man777) and several radiator options. What I'd like to find out is if this leaky end-tank issue was fixed in later model GX's (I have a 2005) or if there's a radiator that doesn't use the stupid crimped on plastic end-tank design (ie welded aluminum end-tanks)?
Old Apr 21, 2010 | 08:42 AM
mr2fast's Avatar
mr2fast
Default bumpity bump bump
ok since no one has replied I'm guessing no one knows. From what I've been able to find, the part number remains unchanged across all years( p/n 2690) of the first gen. This leads me to believe that the problem hasn't been resolved and the only reason it hasn't occurred in later models is they don't have enough miles/wear to have developed the issue.
Anyway since I need to take care of this immediately I'm going to grab the KOYO radiator (p/n A2690) and send my busted one off to be copied and made w/ aluminum welded endtanks. I'll post pics when I do the swap.
Old Apr 21, 2010 | 08:58 AM
mann777's Avatar
mann777
B4 you replace the Radiator, Do some troubleshooting to know the exact nature of leak. And go for the replacement. And always check the condensor which is right in front of the radiator, It is ideal ( not neccessary) to have them changed in tandem. And Koyo are 2 types one is Copper / Brass and the other all alumunium. The options are based on the what you would like suiting to your budget. The best performance are the alumunium based ones.
Old Apr 22, 2010 | 06:35 AM
jditom's Avatar
jditom
Some of the OEM tank were defective. I would just get a KOYORAD and should last you the life of the rig.
My story is below.
I thought I would add to this tread since I just also replaced my radiator. I have read that there is a higher number than normal radiators that are prone to leaking from 2003-2006 in V8 Lexus/Toyota platforms.
I got my 2005 GX 3 weeks ago and have been busy base lining all the fluids and filters when I came across a small leak around the lower driver side. This was missed by the Lexus inspector! Small drops of antifreeze were on the sway bars and it was crusted on the lower part of the radiator. Apparently this is a common area of failure.
Replacement radiator from Lexus $800, parts alone. The first after market one I got was from AutoZone, made in India for $269. It was a POS! Fins were not evenly places and the core was ¼ inch thinner than OEM (that’s a lot of surface area lost).
I got a tip from my Toyota parts guys who called
https://www.1800radiator.com/
They got me a Koyorad radiator. Made by Koyo in Japan. I know Koyo products mainly from replacing the bearing on my Landcruiser. Toyota uses Koyo bearing for there OEM parts. Paid $294 and it was absolutely flawless. An exact match to the OEM in every way. What a difference and only $25 more with a lifetime warranty.
http://www.koyorad.com/
The only thing I can add to Mann’s excellent write up is that I bought a special spring hose clamp pliers form NAPA ($26). Since that lower hose is a b****! And it made the job much easier. Right tool for the job (words to live by)!
http://www.napaonline.com/MasterPage...e+Clamp+Pliers
While I was doing the radiator I also replaced the main upper and lower hoses, thermostat and gasket. Total cost with Toyota lifetime antifreeze was about $400.
All is good now
Old Apr 22, 2010 | 08:08 PM
mr2fast's Avatar
mr2fast
thanks for the replies..
man777 - I'll be going with the aluminum KOYO radiator (i didnt even see the brass one)
jditom - thanks for sharing your story, your original post is actually in the thread I linked. I'm curious though, you say:
My story is below.
do you have any information to support the fact that the problem is limited to the 03-06 models? And since the Koyo radiator has the same part number as the OE radiator is it possible that they were the OE supplier ?
Old Apr 22, 2010 | 10:33 PM
S8KWR's Avatar
S8KWR
+1 For Koyo's. I upgraded my Miata's radiator to a Koyo after my tanks exploded during a race while waiting in line. I raced with that radiator for 5 seasons, I was one of the only guys that would sit in line with the engine on and a/c pumping. Car never even thought about running hot. Great quality, great fit, and yes...it will outlast your rig.
Old Apr 23, 2010 | 06:38 AM
jditom's Avatar
jditom
I just checked out multiple forums and it seemed to only be mentioned in some of the earlier year production. Do not know if Koyorad make the OEM one. Sure looks like it. When you get yours and compare you will see there is no difference. But you can sleep easy with a lifetime warranty.
Old May 6, 2010 | 09:36 AM
gx470_05's Avatar
gx470_05
Thanks for all the information.
I am in need of replacing my radiator as well. Not sure if I want to do it myself or take it to the shop. My main concern is the transmission fluid. Since the transmission lines connecting to the radiator has to be reconnected, do you need to add new ATF and how would you add it since my 05 gx470 is a close system?
Thank you.
Old May 6, 2010 | 01:40 PM
mann777's Avatar
mann777
Thank you.
Sorry Mate, where do you get this info Trans lines connected to the Radiator I suppose you are trying to say the coolant, iso ATF if i am right.
Old May 6, 2010 | 04:20 PM
gx470_05's Avatar
gx470_05
Default Mann777
Sorry, I meant the ATF lines.
From step 4 of your post on how to change the radiator:
"Now seperate the Fan shroud . and then disconnect the Radiator Hose which is at the top Right end. and another one at the bottom left also. Then you disconnect the Oil cooler inlet hose".
Would I need to add ATF after installing the new radiator? and how would I go about doing this since it is a closed system?
Thank you for your help.
Old May 6, 2010 | 10:16 PM
hammer0008's Avatar
hammer0008
Allow the engine to idle with the air conditioning OFF...Fill the transmission through the refill hole until fluid begins to trickle out of the overflow tube
Old May 7, 2010 | 07:01 AM
jditom's Avatar
jditom
I only saw a couple of drops lost in the procedure.
Don't try to fill your ATF unless you know what you are doing. It is a closed system.
Disconnect the hoses and keep them pointed up or tie them up and there will be almost no ATF lost.
Old May 7, 2010 | 10:38 AM
gx470_05's Avatar
gx470_05
Thanks for all the replies.
One last question:
jditom I only saw a couple of drops lost in the procedure.
Won't there be some ATF left in the old radiator? Sorry for all the questions. I just want to make sure before I start on it.
Thanks again.
Old May 7, 2010 | 06:38 PM
hammer0008's Avatar
hammer0008
One last question:
Thanks again.
I suppose that the amount is not significant because the factory manual has nothing about adding ATF after radiator install. But to be safe I would add until overflow and the little bit of oxygen you introduce to the sealed system won't do anything.
Old May 8, 2010 | 10:14 AM
mann777's Avatar
mann777
The inlet cooler tube is only disconnected, but there is no loss of oil. The safest way to avoid the pour down is you could plug the tube with some plastic into the tube vents. But there is no top up to this effect. It is a straight forward replacement of the radiatior and the coolant. One important thing is check out the hose condition( like do they look warped or any minor cracks). This would be the ideal time to do it once and for all.
