Is there a DIY for replacing steering rack?
Old Mar 3, 2013 | 01:57 PM
Dx3's Avatar
Dx3
Default Is there a DIY for replacing steering rack?
About to replace rack and was wondering if anyone had a DIY for an SC300? I just replaced the rack bushings so I'm ok getting that far = more so the steering linkage and tie rod ends?
Thanks,
Jonny
Old Mar 3, 2013 | 02:13 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
From the FAQ, not super detailed but may help
https://www.clublexus.com/forums/sus...nt-how-to.html
Old Mar 4, 2013 | 06:06 AM
kmoore737's Avatar
kmoore737
Where did you buy the rack bushings?
Old Mar 4, 2013 | 05:09 PM
Blkexcoupe's Avatar
Blkexcoupe
Thanks,
Jonny
It's only a few more bolts after the bushing install. a cotter pin, and a nut on each tie rod end. 2 bolts for the hydraulic ps line, and 1 linkage bolt which is the hardest thing to align.
Here is a good diy:
https://www.clublexus.com/forums/sus...ement-diy.html
figs engineering sells superpro bushings or you can get whiteline bushings directly from whiteline.
Old Mar 11, 2013 | 01:06 PM
Dx3's Avatar
Dx3
Awesome - thank you Dave
Here is a good diy:
Thank you sir So do you not need a pitman puller? Why do I keep reading about needing this?
Old Mar 11, 2013 | 01:29 PM
k7q's Avatar
k7q
Puller is preferred, but you can use a hammer and hit the knuckle to get the tie rod out.
Puller would make it easier.
Rent it from a auto part store and return the same day and they shouldn't charge you.
Old Mar 17, 2013 | 06:56 PM
Dx3's Avatar
Dx3
Got the puller which made it much easier - thank you
SlkySmooth
Feb 17, 2026 01:55 PM
Paulanth
Dec 1, 2018 08:59 PM
bartsitars
Sep 9, 2014 04:17 PM
Iparkcars
Suspension and Brakes
Apr 12, 2013 04:02 PM
