95 SC300, no brake lights
Old Feb 21, 2013 | 01:09 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Default 95 SC300, no brake lights
As many of you know that I am working on Jays 95 SC. While I have it, he also wants me to look at a few things to try and figure out. One of his problems is the rear brake lights will not come on. His running lights work, turn signals, tag, and reverse, but NO brake lights. I have checked the bulbs, and ALL the fuses. Inspected the wiring, and then rechecked the fuses yet again. They are all good. I looked at his brake sensor on his pedal, and it is indeed there and not broke. He has an aftermarket alarm installed and it is a Python with remote start. He also had an auto car and now converted to a V160 and had Dr. Tweak do the harness. His cruise control is completely removed, just the plug hanging. I also have his radio, center console, climate control, and the trim under the cluster out. He also has a Greddy turbo timer and Greddy boost controller installed. I didn't think this would make a difference, or would it? This has got me stumped. I thought for sure it was the brake sensor on the pedal, but it aint, or is it maybe bad? One post stated there is a sensor under the driver side dash, color blue, does this control the brake lights?????
I searched and all the links to the same problem, all the threads are dead, and only a few replies. I need these working before he picks it up.
Any insight on this?
Old Feb 21, 2013 | 01:31 PM
99SC42's Avatar
99SC42
Did he replaced the tailights to a newer tailights?
There is a tailight ecu right by the antenna motor on the driver side quater , it's a black box make sure it plugged in, or swap the box with yours.
gl
Old Feb 21, 2013 | 03:40 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Will try that when it stops raining. Thanks Quick
He has the original taillights.
Old Feb 21, 2013 | 05:47 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I did see a small thin 2 prong wire under the dash for the alarm, but didnt see where it went. All the prongs on the alarm brain are full. I am thinking it went to something in the dash that I removed from Jays car, that wasnt needed. I will look more into this tomorrow.
Old Feb 23, 2013 | 03:20 PM
supraclone's Avatar
supraclone
come on guys, the tails work and the brakes light up when u arm the alarm. but no brake lights when pressed......
Old Feb 24, 2013 | 05:08 PM
99SC42's Avatar
99SC42
Swap the brake switch to see..
Old Feb 25, 2013 | 03:10 PM
BattleVer's Avatar
BattleVer
power goes to the brake light switch
then power goes to that box in the trunk (ive had that break before)
then power lights up the bulbs
use a test light.
Old Feb 25, 2013 | 03:52 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
It was the brake sensor on the pedal. Worked great. Life is good now. Thanks for all the replies.
Mesh704
Apr 19, 2024 05:26 AM
sdwilkins
Aug 29, 2017 07:19 AM
Patr1ck
May 2, 2017 07:32 AM
ji09051
Dec 3, 2005 09:05 PM
