Idle Problem-Video
Old Feb 9, 2013 | 01:47 PM
Kpierce007's Avatar
Kpierce007
Default Idle Problem-Video
Hey guys, My Sc400 does this thing where it will drop from about 1,000 RPM (where it usually is) to around 200 then no idle. If I take my foot off the gas it will just die so I have to drive with one foot on the gas and one on the break. It doesnt do this often but it just randomly does it and will just randomly start idling again. Any Ideas what the problem could be?
Old Feb 9, 2013 | 01:55 PM
xxtoobsxx's Avatar
xxtoobsxx
have you checked for codes? looks like you have a CEL!
Old Feb 9, 2013 | 01:58 PM
Kpierce007's Avatar
Kpierce007
I haven't ran the codes yet, I need to
Old Feb 10, 2013 | 07:17 AM
Bankswood's Avatar
Bankswood
Could be TPS, dirty IAC valve. Have you done the fuel pump ECU mod. If not I would do that first then work on the other things.
Old Feb 10, 2013 | 07:40 AM
Kpierce007's Avatar
Kpierce007
Ok thanks, what exactly is the fuel pump ecu mod?
Old Feb 11, 2013 | 05:44 AM
Bankswood's Avatar
Bankswood
Follow these instructions. Very easy
https://www.clublexus.com/forums/perf...tures-faq.html
Old Feb 11, 2013 | 09:06 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Once you try the Fuel Pump ECU mod, if it doesn't work, I'd go to the TPS. I'd set it to spec with an ohmmeter. Your TPS could be out of spec. IMO, it look's like a TPS issue...but FIRST, pull the codes!! You don't wanna be replacing parts randomly hoping that they will correct the issue.
BTW, my CEL on my SC doesn't work.... It could be a long list of stuff, just pull the code(s) and go from there.
Old Feb 11, 2013 | 01:48 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
pull the cel and post it back up here before doing anything else, unless you want to do mods semi-randomly hoping one of them will work, which is plan B when there is no cel. Fortunately, you are still game for plan A.
Old Feb 11, 2013 | 09:28 PM
Kpierce007's Avatar
Kpierce007
Hey guys, I seafoamed it yesterday and changed the oil. This helped my car run better but it still didnt idle. This morning I started it up and same thing, However after about 2 minutes I got it to idle about 400 RPM. Then it just climbed up to 1,000 and stayed their. It now runs and idles perfectly. Think the seafoam did anything?
Old Feb 11, 2013 | 09:50 PM
k7q's Avatar
k7q
check if intake coupler is torn.
check the CEL. would be easier also
Old Feb 12, 2013 | 08:59 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check CEL, then reset the ecu, in that order. report back on cel.
Old Feb 12, 2013 | 05:43 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
The seafoam probably did do something if what you say is true...pull the CEL code then report back to CL!
xCWolf
Sep 1, 2018 02:14 PM
flosssc
Aug 5, 2015 08:49 PM
millertime
Jun 21, 2013 09:15 PM
esco2114
Feb 11, 2011 02:35 PM
sweetsc400
Aug 8, 2003 05:15 PM
