slight clunk feeling when shifting
hey i have a '92 sc300 5-speed with only 83,000 miles on it. when i shift (especially from 1st to 2nd), i feel a little clunk going into gear. the higher the rpm the bigger the feel & vice versa. is this due to low tranny fluid, or the ever fun syncro's. i did notice a small oily spot around tranny like a possible leak or old leak. how do i check tranny fluid, where is the fill hole?
While you're under the car, I'd flush the differential fluid as well. Drain plug is the bottom one. It's a magnetic 8 or 10mm allen head bolt. Fill plug is just above it.
-scott
thanks for the info, also how did the 6-speed swap go? was it straight forward? how much was the total swap?
thanks again for the info.
http://www.supraforums.com/showthrea...threadid=89292
-scott
P.S. you're welcome!
wow, $5900 in parts is a pretty expensive swap. sounds cool though! good job!
Next time, I'd lurk around in the supraforums classifieds looking for deals on clutches, flywheels, tranny mounts etc. Unfortunately, a *good* 6-speed with *all* the parts is going to cost you $$$. Additionally, the 6-speed LSD requires a new rear axel because the pumpkin is narrower than the 5-speed/automatic differential. Consequently, I went with the TT automatic LSD.
-scott
Soaringhigh: You're talking about an automatic, he's got a 5 spd.....a few differences.....
I have the weird clunk you speak of when shifting from 1st to 2nd and I'm not gonna wait to find out what it is.
I'm doing a full flush today. =)
SuperCoupe400
Jul 29, 2009 04:49 AM
lukey33
Jan 29, 2004 05:35 AM
