Heavy Tranny Clunk When Shifting @ Standstill
Old Jul 27, 2009 | 10:51 AM
SuperCoupe400's Avatar
SuperCoupe400
Question Heavy Tranny Clunk When Shifting @ Standstill
For a long while now I've been getting an unusually loud and heavy clunk when shifting between drive, reverse and neutral (shifts while driving are fine) - but only when the tranny is cold. After driving a few miles, it'll go through the gears fine. My problem is at standstill only.
I just did a tranny fluid change (just 4 quarts - not a full drain and refill) but I'm still getting the abrupt shifts. It was suggested that it might be a tranny fluid vescosity issue - meaning that if I do a complete drain and refill that the problem would be solved. I'm not so sure I buy that, because with 50% of the fluid changed I should be able to feel some difference.
BTW, the tranny pan was pretty darn clean. First time I've changed the fluid in the five years I've had the car ('93) and there was just a tiny amount of metallic dust on the magnets. No particles or fragments whatsoever.
Any suggestions?
Old Jul 27, 2009 | 02:40 PM
UpInTheLex's Avatar
UpInTheLex
Got me on this one. I sure would like to know.
The mounts are all good?
Old Jul 27, 2009 | 07:54 PM
bodydrager's Avatar
bodydrager
I get a similar sound but I know its just my lower control arm bushing.
Old Jul 28, 2009 | 04:15 AM
SuperCoupe400
Just changed my tranny mount a year ago. So that can't be it.
Haven't hit the engine mounts yet, but I seriously doubt those are the culprit anyway.
I had my brother cycle through the gears with me standing at the engine bay and from there all seams normal. The "clunks" are only audible from within the cabin. You can really feel the car lurch as each gear engages.
So nobody's had this happen before?
I'll be changing the diff fluid soon. Hopefully that fixes it.
Old Jul 28, 2009 | 06:59 PM
TheMole's Avatar
TheMole
The drain and fill on my 93 sc300 should be about 2 quarts. Not sure if its the same on the sc400, but maybe something to consider. Since it was happening before the fluid change, this may not be the case.
What type or atf did you use?
Old Jul 28, 2009 | 07:24 PM
jdm93400's Avatar
jdm93400
holy freakin cow . im havin the same problem. i put it up on a lift last wek to check all my mouts and they are a ++ . i had my tranny replaced a yr ago and its been doing it since they put it in. iv never ahd any problems out if beside that clunk it does it only when cold after it warms up it stops. it really feels like a mount . when u figure this out please tell me i been wantin to knwo for a yr wat it is
Old Jul 29, 2009 | 04:49 AM
SuperCoupe400
Well, actually only about 3.25 quarts drained, but it took 4 to fill level. So essentially I was running about .75 quarts low.
I used the recommended Toyota Type-IV ATF.
And as you pointed out, it was happening prior to the fluid change. Maybe it was caused by the low fluid level. But assuming no damage was done (I found only very minor metal dust on the magnets), I'd think that topping off ATF would fix the issue.
iGS430
Dec 18, 2015 11:38 AM
Rezaxxed
Performance
Sep 24, 2008 05:28 AM
Answer300
Performance
Jan 8, 2008 11:20 PM
fasthuh
Performance
17
Feb 26, 2002 12:21 PM
SCV8
Performance
Aug 21, 2001 10:04 PM
