Coilover guys, inside!!
Old Dec 22, 2012 | 06:12 PM
megamax's Avatar
megamax
Default Coilover guys, inside!!
so since this sc suspension is still kinda new to me,i have a question for the guys running true coilovers???
do you guys have adjustable camber plates on the front premium or even cheap coils??
i can't find any pics of any sc or mk4 supra with adjustable front pillowball mounts. i see the pics for the ones for sale like ebay and what not. but some of them are for reference and aren't actuall item.
and the ones thatactually are for our cars are shot from the side. and dosen't appear to have adj camber plates(like on a nissan 240sx).
do our cars utilize these??
Old Dec 22, 2012 | 07:51 PM
k7q's Avatar
k7q
front CAMBEr plates on our SC's wont give us more camber.
240 has them before the coilovers are mounted on the knuckles. where the SC is mounted on the LCA
Old Dec 23, 2012 | 12:36 AM
ArodDaLob's Avatar
ArodDaLob
double wishbone = camber plates won't change camber.
sc is double wishbone front and back. racekar teknology.
you can install some camber plate upper mounts but they won't do much. it'll look pretty cool though.
Old Dec 23, 2012 | 05:11 AM
megamax's Avatar
megamax
Ah, now u guys tell me. So even the high end hks hipermaxes don't have upper camber plates? See, u don't know unless you ask.
Old Dec 23, 2012 | 05:15 AM
megamax's Avatar
megamax
So I gueSs megan ez streets is the way to go. I got some megan lowering springs. But for some brand new wftermarket(struts alone) I can't beat 600shipped. Wtf! So much for struts might as well get the megans.
Old Dec 23, 2012 | 12:02 PM
ArodDaLob's Avatar
ArodDaLob
no, think about why the s13/4/5's will be affected by camber plate. the coilover is bolted through 2 bolts to the knuckle/hub itself. angling the coilover, then, will angle the hub, therefore altering camber. That's pretty much how all macpherson strut systems are.
On the sc, though, you can angle the coilover all you want, but all you'll do is pivot the coilover system around its mounting bolt on the LCA. I'm sure suspension geometry will be affected, but won't do anything to the camber. You'll need to do all your alignment alterations through the arms since the arms and tie rods are the only things grabbing onto the knuckle, therefore, the only things that can change the direction the knuckle faces.
So no, HKS has no real reason to put cost-adding camber plates on the sc/mk4 coilover systems they sell.
Old Dec 23, 2012 | 01:24 PM
SFrymyah's Avatar
SFrymyah
My ez streets ride awesome but I have huge issues with the front tires bottoming out on the frame. Changing the front springs to 14kg rates helped an unbelievable amount
Old Dec 23, 2012 | 06:37 PM
megamax's Avatar
megamax
thanks guys.....
THE MORE YOU KNOW!!!
Old Dec 24, 2012 | 08:08 AM
Candela's Avatar
Candela
You know how on a 240, you buy those rear upper control arms to adjust camber in the rear?
Well on SC/Supra, its the same thing, but for the front AND rear.
Like Arod said, superior racekar teknology!
Old Dec 28, 2012 | 10:45 AM
CircuitMS's Avatar
CircuitMS
If you want some help on coilovers hit us up, we do a lot of suspension work and we will be happy to help out any Forum members on setups!
Old Dec 28, 2012 | 06:56 PM
megamax's Avatar
megamax
Will do, thanks again. Also does the mk4 and the sc have the exactly same front and rear suspension system? If not aside from springs and shocks, what's the diff?
Old Dec 29, 2012 | 10:48 AM
Candela's Avatar
Candela
supra/sc same suspension/subframes/knuckles/etc. on a supra the rear spring perches are higher, also all springs are lower/stiffer than sc. to use supra shocks u must also use supra springs. when it comes to coilovers it doesnt matter cuz its all 1 unit put together.
NavAv
Suspension and Brakes
Mar 6, 2011 05:17 PM
llcjr
Nov 13, 2010 01:44 PM
Peaceful
Oct 23, 2010 04:34 PM
Biggu
Sep 17, 2007 11:48 AM
soardrft
Nov 16, 2005 07:06 AM
