Help ID Cut Wire
Old Dec 3, 2012 | 08:52 PM
TheAzn's Avatar
TheAzn
Default Help ID Cut Wire
I was looking under the hood of my SC3 and noticed the plastic wire covering going of the passenger wheel well cracked. I took a look, able to pop it up and noticed a PINK / BLACK STRIPE wire cut. Anyone knows what it is for?
Old Dec 3, 2012 | 09:34 PM
rcchris7's Avatar
rcchris7
I can't remember for sure but I think there is a pink/black wire people cut as a "mod"
Old Dec 4, 2012 | 11:44 PM
TheAzn's Avatar
TheAzn
The only things I can find is some mod for automatics to shift differently or whatever. My SC is a 5 speed so I don't think it would pertain to that.
But I wonder... If someone did a manual trans swap completely, including the cluster, as if all factory... is there an ID plate on the car or something to tell if the car came as an automatic or stick from factory? I doubt if it was a swap, unless they did a damn good job.
Old Dec 6, 2012 | 10:14 PM
emoFTW's Avatar
emoFTW
I know that people cut a "pink wire" on a 1jz in order to eliminate speed cut. But I'm assuming your car is still 2jz-ge?
Old Dec 7, 2012 | 07:53 AM
rcchris7's Avatar
rcchris7
Check your ecu it will say a/t or ,m/t if they bought a crashed car as a donor they could have done a factory swap
Old Dec 7, 2012 | 09:58 PM
TheAzn's Avatar
TheAzn
Nope, it's a true manual.
Old Dec 8, 2012 | 04:40 PM
ND92Lexus's Avatar
ND92Lexus
I just gutted my chassis harness and I know I pulled that wire. Could be multiple things, ABS, trac control, sensor by the hood latch, or air bags. Two of those would easily be detectable. If u obviously don't have abs or trac control.
CobraGSF
Dec 18, 2014 09:17 PM
evileagle
Dec 1, 2009 08:13 PM
m32
Mar 13, 2008 03:28 AM
owali
Nov 19, 2007 01:30 AM
mjr24
Sep 19, 2002 12:02 AM
