1jz Upgrade
Old Nov 24, 2012 | 11:07 AM
speed6's Avatar
speed6
Default 1jz Upgrade
It's time to upgrade my stock twins.
What turbo should i upgrade to.
I want a quick spooling, not too laggy turbo that makes power down low and linear like the stockers, but i dont want to boost it too high, nothing over 14-15psi.
Any suggestions?
(i could also upgrade my stockers to 2860RS spec, but i've heard that they go out often)
Old Nov 24, 2012 | 02:52 PM
Toyboxx's Avatar
Toyboxx
Holset HX35, or Borg Warner S300
Old Nov 24, 2012 | 04:22 PM
Kire's Avatar
Kire
A 6262, 6265, or GT35 would also be a good option. What are your goals?
Old Nov 24, 2012 | 11:08 PM
speed6's Avatar
speed6
400, reliable, quick spool, power down low.
Old Nov 25, 2012 | 02:16 PM
Candela's Avatar
Candela
Old Nov 25, 2012 | 04:57 PM
speed6's Avatar
speed6
Originally Posted by Candela
I thought the arms kit was vvti only.
Old Nov 25, 2012 | 05:01 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I say S362 or S360 for the quick spool. Upgrade the cams also and get a great tune on 93 and you will be set. My S366 is laggy but it makes me drive it like a regular car, until it hits boost at 4900 or so... Yeah I know thats high, but point it straight when it comes in... I bought this turbo for room to grow in the furture of possibly stage 3 cams, and valves and so on, and maybe a 2JZ block. The BW are cheap to rebuild, so keep that in mind also... JMO.. GL on your choice. MY vote is ANY BW turbo...
Old Nov 28, 2012 | 12:37 PM
speed6's Avatar
speed6
money is kind of a factor. I was think an oil journal bearing turbo.
Also quick spooling is a priority.
Should i hack my t4 manifold and put a t3 flange and t3 turbo on it?
I'm buying a china turbo (yes kill me now).
i want to run a .58 AR exhaust wheel for a quick spool while i build my Twin turbo manifold for twin 2680rs spec turbos.
Old Nov 29, 2012 | 07:32 PM
KahnBB6's Avatar
KahnBB6
There is a company that will rebuild the stock ct12a twins with steel blades and possibly a slight increase in maximum boost efficiency to about 14psi. I have forgotten the name but they still do it. They may be the only company that does this service. Drift motion doesn't touch CT12A's. That Tomei Arms turbo kit is indeed for 1JZ VVT-i engines only-- but for those it is bolt on.
Further info in this thread: https://www.clublexus.com/forums/per...o-upgrade.html
Last edited by KahnBB6; Nov 29, 2012 at 07:44 PM. Reason: Referring to local thread on stock twins topic
Old Dec 3, 2012 | 03:24 AM
KahnBB6's Avatar
KahnBB6
if you want single turbo on a budget, he can help you out too. he does all kinds of turbos, or, you could buy any holset, he351, hx35, hx40, h1c, etc etc they all spool fast and put down decent power for a budget build. but holsets are t3 footprint so you'd have to buy a t3 manifold or buy a t3/t4 adapter plate[/quote]
The OP's criteria are pretty close to what I'd want. I've read good things about HX35's, too from Ford 2.3T SVO guys. It just seems like a great all around budget turbo with decent flow if you're not going crazy.
Old Dec 5, 2012 | 08:48 PM
FastCarsBG's Avatar
FastCarsBG
A guy named Jeff at Turbo Auto in Nashville Tennessee can do the upgrade on the stock twins and get really good results if you want to "fix" the stock ones and make 400 reliable hp!
Hope this helps!
chris1jz
Nov 9, 2012 12:37 AM
Gabep
May 17, 2012 08:26 PM
Psionic
Jun 20, 2006 05:48 PM
soardrft
Oct 28, 2005 05:48 PM
Kstyle55
Apr 19, 2005 05:49 PM
