1992 SC400 failed smog in CA
Old Sep 20, 2012 | 08:15 PM
jrpetrie's Avatar
jrpetrie
Default 1992 SC400 failed smog in CA
the reason it failed is the NO(PPM)is at max 530 at 15 mph and 487 at 25 mph. I am new to this forum but mechanically inclined
Old Sep 23, 2012 | 08:19 PM
jrpetrie's Avatar
jrpetrie
ok . I just bought this car, 140,000 miles very clean, when i drove it hard i noticed a slight miss so I bought plugs,wires caps and rotors, (these vehicles are not the easiest cars to work on, I must be getting old) when I took the plugs out 3 of them were loose and 2 of them were so tight I had to use an air ratchet, i would have to assume there was no lube put on the old plugs, now the car runs hard so I'm going to try to smog it again, any assistance would be appreciated
Old Sep 24, 2012 | 02:14 AM
GTX580's Avatar
GTX580
Failed smog twice but just passed on my 206k sc3... high nox (2XXX @ 15mph, 7XX @ 25mph) with borderline passing HC.
Did my reading and found out high nox is related to EGR. I cleaned the EGR and passed.
Old Sep 27, 2012 | 01:35 PM
jrpetrie's Avatar
jrpetrie
well , went for a retest after changing oil,air filter ,plugs,caps ,rotors and cleaned the EGR valve and still failed, what should I look at next?
any help greatly appreciated
Old Sep 27, 2012 | 01:36 PM
jrpetrie's Avatar
jrpetrie
should I try saefoam through the PCV hose
Old Sep 27, 2012 | 07:56 PM
GTX580's Avatar
GTX580
did you perform a vacuum test and see if yr egr is working?
Old Sep 29, 2012 | 04:17 PM
jrpetrie's Avatar
jrpetrie
i did suck on the hose going to the EGR and the car died, i have put seafoam in through the PCV hose about 1/2 a can then ran it a bunch of crap came out then got my oil changed, put a can of Guaranteed to pass ran through the tank and my NOX levels went up
really need some help here
Old Sep 29, 2012 | 10:04 PM
GTX580's Avatar
GTX580
did u clean the little elbow with the tiny screw on the EGR valve?
Old Sep 30, 2012 | 08:11 AM
jrpetrie's Avatar
jrpetrie
where is that? I took the EGR off and cleaned the ports but I left the aluminum piece on. i will take it off today and clean it
Old Oct 1, 2012 | 01:31 PM
jrpetrie's Avatar
jrpetrie
Well, I went to the Lexus dealer today and they took a look at it and said it is the EGR Valve Vacuum Switch, I ordered 1 and they will do a pretest on it befor I smog it
BigOSC400
Jul 12, 2015 09:06 PM
taildrager
Dec 28, 2004 03:23 AM
dbullen
Maintenance
Aug 23, 2004 10:47 AM
burnettebr
Maintenance
Sep 25, 2003 08:26 AM
