Starting problem please help!! Vids inside
Old Sep 6, 2012 | 08:31 PM
Piratse's Avatar
Piratse
Default Starting problem please help!! Vids inside
Okay folks,
I have fixed about 50 little gremlins with this car in the past few months. The (hopefully) last one that plagues me is that the car won't start in the morning. EVER. Come home in the afternoon for work, BAM starts right up. I though it was some security thing because when the car starts it drives just fine (now). No stutter, no hesitation, doesn't overheat etc. This car has new;
Plugs/wires
Distributor rotor
ECU (still thinking this may be the cause but not sure)
Fuel pressure reg
Has good fuel in it (1/2 tank but the amount never seems to effect it)
Links to the Videos of the start and not starting. There is one F bomb in the second video so pardon that.
http://s208.photobucket.com/albums/b...0725-00000.mp4
http://s208.photobucket.com/albums/b...0725-00001.mp4
Old Sep 6, 2012 | 08:43 PM
salimshah's Avatar
salimshah
25 Year Member
In the morning start, try to hold down the the throttle a bit ,,, say 1/4 to 1/2 way.
If that helps look in to
https://www.clublexus.com/forums/per...talls-out.html
Salim
Old Sep 6, 2012 | 08:46 PM
Piratse's Avatar
Piratse
Salim
Done that. I've tried every which way with the ignition and throttle to get it to start. Nothing. Turn it on a few times and off to build fuel pressure, different throttle positions, everything.
Old Sep 10, 2012 | 04:08 PM
Piratse's Avatar
Piratse
No one? C'mon fellas I need some help. It is driving me nuts and I'm sick of paying for parts that don't fix it.
Old Sep 11, 2012 | 09:07 PM
GS4_Fiend's Avatar
GS4_Fiend
Did you try checking for codes? It's pretty hard to diagnose something like this online with little info. i would check to see if your throttle body is clean and clean the IACV while you are at it.
Old Sep 11, 2012 | 11:39 PM
durps's Avatar
durps
Try turning it on with the maf disconnected, reset your ecu, do the 12v fuel ecu mod.
Are you sure its not the lexus antitheft killing the starter? Do you always unlock the door with the keys. Not the remote unlock.
Old Sep 12, 2012 | 07:49 AM
Piratse's Avatar
Piratse
No codes, throttle body is clean (took it apart). Will look at IACV
I did the 12v mod. I do unlock the door with the key, don't even have a FOB. I will try the MAF thing.
whiteysc
Aug 3, 2011 02:42 PM
ksort86
Mar 7, 2009 09:09 PM
rsp169
Jan 12, 2009 08:08 PM
na4now
Aug 10, 2007 12:29 PM
kathleenkmh
May 23, 2002 05:31 AM
