car finaly gave up maybe?
Old Sep 3, 2012 | 10:38 PM
whooper20's Avatar
whooper20
Exclamation car finaly gave up maybe?
i think my car just finally gave up, maybe? >:/
so i was moving my car so i could park the honda on the street and when i put in first, let the clutch go, and slightly creeped out while turning to the left to see if car was coming, then the car cracked loud and my steering stiffened up badly, now its like i have no P.S and i cant even drive it.. my clutch was slipping but im sure it has ntn to do with it. i only moved it a couple feet and i havent had any issues but the clutch recently started today
Old Sep 3, 2012 | 10:39 PM
whooper20's Avatar
whooper20
also my battery light came on and other warning lights
Old Sep 4, 2012 | 08:45 AM
1uzSC's Avatar
1uzSC
Threw a belt probably and u probably froze up ur waterpump or another pulley
Old Sep 4, 2012 | 10:16 AM
lmfod's Avatar
lmfod
Sounds like snapped drive belt. Check that all the pulleys spin smoothly.
Old Sep 4, 2012 | 10:21 AM
lmfod's Avatar
lmfod
Water pump is driven by timing belt. If the timing belt broke that would be a whole other set of problems.
Old Sep 4, 2012 | 10:44 AM
codetoad's Avatar
codetoad
Lol. Come on bro's. Let's not put out incorrect info. A water pump has nothing to do with the timing of the crank and cams. Your serpentine belt/drive belt is fubar. That's why your power steering is gone and your alternator isn't charging/ battery light is on. Buy a new one.
Old Sep 4, 2012 | 10:52 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
open hood, look for the belt thats ripped to shreds. replace.
Old Sep 4, 2012 | 02:48 PM
lmfod's Avatar
lmfod
I'm not putting out incorrect info. No one ever said anything about timing issues. If you read my post before I said the exact same thing as you. Drive belt aka serpantine belt aka accessory belt snapped. I was simply trying to correct the other post mentioning the water pump pulley and I was stating that the OPs problems have nothing to do with water pump.
Just to clarify
XxSC400xX
Aug 1, 2013 03:34 PM
Slvr surfr
Sep 20, 2010 11:00 PM
Felix gs43
Performance
Oct 8, 2006 10:31 PM
damon
Maintenance
May 17, 2005 07:38 AM
