SC- 1st Gen (1992-2000)
Sc400 to manual clutch pedal assembly question (having a small issue)
Old 08-06-12, 11:27 AM
marcojdm
marcojdm's Avatar
Default Sc400 to manual clutch pedal assembly question (having a small issue)
Hey what's up guys! I'm the guy that put the ka 5 speed in my sc400. Car has been driving about a month and everything has been moving flawlessly except for one issue. My clutch pedal assembly was really flimsy. It would flex whenever I pushed the pedal causing the pedal to hit the floor before the clutch was engaged all the way.
We took the assembly out and added some bracing and it helped a lot but now it seems to be getting worse.
I have the 2 bolts by the master cylinder and then we added a bottom bolt at the bottom to see if it would help and it's not.
I am using an sc300 manual clutch pedal assembly and pedal. Any recommendations would be greatly appreciated guys!
Old 08-06-12, 11:58 AM
charley240
charley240's Avatar
When i mounted mine, i cut a square roughly the size of the brace out of the padding so that it would sit flush. It sounds like you need to cut padding. Because there are only 3 screws which fix the brace, and i onlu used 2 and it seems to be sturdy. Unless youve got hulk legs, it does sound like a parding issue.
Charley
Old 08-06-12, 05:31 PM
marcojdm
marcojdm's Avatar
I'll take a better look at it tomorrow. It seems more like my assembly is flexing. There was a crack when we took it off the first time.
Would you happen to have any pics for reference? Thanks a lot man!
familydude
IS - 1st Gen (2001-2005)
10-17-22 03:55 AM
kolessc400
Performance & Maintenance
04-20-14 08:35 PM
xtra
10-17-13 10:37 PM
iduntnoega
10-10-09 08:13 AM
TLDriver
07-10-08 11:42 AM
Quick Reply: Sc400 to manual clutch pedal assembly question (having a small issue)
