Heat problems
Old Jan 25, 2012 | 06:23 PM
msc300's Avatar
msc300
Default Heat problems
Okay waterpump was bad heat worked great replaced it heat blows warm not hot new radiator, themostat , rad cap, coolant flush, also heater core flush, also tried heater control bypass still blows warm its an sc300 206k doesnt over heat couldnt head gasket be problem
Old Jan 25, 2012 | 07:19 PM
WadeLovell's Avatar
WadeLovell
If I understand correctly, you have replaced the waterpump, radiator, thermostat, radiator cap, flushed the coolant and heater core (BINGO!) and attempted to bypass the heater control.
The original problem leading to all of this was what? Were there any codes then? Are there any codes now?
It is always possible you sent a bunch of crud into the relevant channels in the engine block. Therefore, take a handheld thermal gun and have a quick look for hot spots. I hope you don't have any.
Next, I would remove the thermostat. If you don't get hot water through the heater core with the thermostat out, I am at a loss. I would then suspect you junked up the heater core during the flush. Did you do the flush? If so, that isn't it becaue you would have a decent idea the bloody thing wasn't flowing right.
It would be odd to have the climate control fail coincident with the above repairs.
Old Jan 25, 2012 | 08:56 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
This brings up a good point. My heat quick the other day. It will work good if the rpm is above 3k. If anything below that, its cold. It only has 356k on it. Lol
Old Jan 26, 2012 | 05:38 AM
msc300's Avatar
msc300
No chemicals used for rad flush machine took old coolant out new coolant in, heater core flushed with water problems started after replaced water pump
jasepb
Apr 11, 2019 03:07 PM
Farino81
Dec 13, 2009 10:06 PM
ekrebs
Dec 2, 2008 07:31 PM
Grier
Oct 19, 2005 11:36 AM
