egr - Code 71....HELP
Old Aug 4, 2012 | 04:49 PM
SCME87's Avatar
SCME87
Default egr - Code 71....HELP
Hey guys...so I recently picked up a 95 sc300...been having some issues with it.
I have a code 71 which is for EGR malfunction. I searched and read that most people just put block off plates...so I decided to go that route.
I took the egr valve & vacuum modulator out along with temp sensor and pipe...put the block off plates on, placed a 10k ohm - 1/2 watt resistor into the harness, reset ecu and the code 71 still came back on after driving approx 30 miles.....
I am not sure which lines to take off on the throttle body so I left it as is & capped off the 3 ends on the hardline that runs under the y-pipe. I know those hard lines can be taken off which I think ill be doing next but what is the correct way to reroute the lines or which do I cap? and do I NEED to take out the pipe in the intake manifold? or is all what I already did sufficient? I am tired of seeing the CEL light on and need this fixed asap!! its killing my mpg!
Old Aug 4, 2012 | 05:02 PM
SCME87's Avatar
SCME87
bumppp..someone chime in
Old Aug 4, 2012 | 09:04 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
the only thing that trips the code is the temp sensor. double check your resistor and the resistence you need.
Old Aug 6, 2012 | 03:01 PM
SCME87's Avatar
SCME87
alright well I'm pretty sure I have the right resistor , its a 10k ohm 1/2 watt....I'll check the resistor to make sure it's properly in.
Can i remove those hard lines that run to the throttle body and just cap them off?
Old Aug 8, 2012 | 06:25 AM
Lexsingle's Avatar
Lexsingle
If you can cap both end of the egr, then you can remove it completely.
Old Aug 25, 2012 | 10:01 AM
SCME87's Avatar
SCME87
alright thanks, problem has been fixed. The resistor was not in properly, so for a better connection I clipped the harness off the old egr and plugged it into the harness on the car, spliced the ends of the wire and tied the resistor to those 2 wires, electrical taped it and zip tied to the side. No more CEL!
Slickcam
GS - 1st Gen (1993-1997)
Feb 29, 2016 05:34 AM
mpm86
Apr 5, 2014 09:56 PM
campoida
Mar 13, 2009 08:38 PM
SDJZZ31
Jun 17, 2005 01:18 PM
Hi-psi
Mar 2, 2004 08:22 PM
