93 SC400 Accelerating Issues
Old Jun 14, 2012 | 03:28 PM
fleshnbone's Avatar
fleshnbone
Default 93 SC400 Accelerating Issues
I have a 93 Sc400 and it has a problem accelerating from a dead stop. I cleaned out MAF.
If the MAF sensor is disconnected there is no accelerating problem, but check engine light it on.
I replaced the MAF sensor from a pick n pull.. I replaced the MAF sensor (black part only) and the check engine light goes away but the problem still there. What can it be?
Old Jun 14, 2012 | 03:50 PM
preston145's Avatar
preston145
Could be a number of things. When you say trouble accelerating from a dead stop I think transmission. Is the tranny slipping?
Old Jun 14, 2012 | 03:55 PM
fleshnbone's Avatar
fleshnbone
No. It doesnt seem like its the tranny. When i unplugged the MAF i was able to accelerate normally with the check engine light on of course.
Old Jun 14, 2012 | 04:56 PM
g4ebguy90's Avatar
g4ebguy90
Well, that means, 1. your MAF is bad, 2. Your replacement maf is bad. 3. CPU is bad. 4. There is something mechanically wrong.
BTW CHANGE THE WHOLE MAF!
Old Jun 15, 2012 | 01:38 PM
Meanshyguy's Avatar
Meanshyguy
I fought with this issue for a long time on my old sc, ended up being a damaged spark plug wire that wasn't making good contact with the plug, make sure they're all good.
Old Jun 17, 2012 | 05:46 PM
mtnrat's Avatar
mtnrat
I also fought this. I had two issues. First my timing belt had skipped a tooth on one side. Once that was fixed it was ok for abut 1/2 a day. Turned out the plug wires and coils had gone brittle and cracked, and were leaking spark. Really check the wires, coils, and plugs before going on the wild goose chase of all the other possible causes.
Old Jun 17, 2012 | 10:39 PM
preston145's Avatar
preston145
These guys are right!^ start cheap work your way up!
Ramses
SC400 / 300 Classifieds
Feb 17, 2013 04:09 PM
SGMIS3
Sep 14, 2011 01:05 PM
lslover92
12
Sep 30, 2009 07:33 PM
chidoks
Mar 25, 2006 08:41 AM
Dx3
Jan 21, 2005 08:59 PM
