My ongoing Sc400 Issues :(
Hey CL. Im still having issues with my 92 sc 400. Car has weak full throttle, overdrive light flashing when engaged. I have replaced the following
Transmission Shift Solenoids
Transmission filter
Transmission Fluid
MAF Sensor
TPS Sensor
Spark Plugs
Coolant
Battery
Cleaned Throttle Body
Seafoam
Changed IACV filter
12v fuel pump mod
No longer throws any CEL, but still struggles to full throttle. The downshift button at the base of the pettle does not work, and this is my biggest problem
. Im thinking ECU, or ignition coil. Suggestions? 240K on the car. Any help is greatly appreciated!
Transmission filter
Transmission Fluid
MAF Sensor
TPS Sensor
Spark Plugs
Coolant
Battery
Seafoam
Changed IACV filter
12v fuel pump mod
I checked and my intake tube is leaking badly. Taped it up a bit and it drove normally for about 5 minutes until the tape broke. Getting a new intake tomorrow , hopefully this fixes the problem!
Are you serious? I feel like the problem is something else. Sometimes it runs mint, shifts perfect and everything. But most of the time it runs slow . I noticed today when I push it in low gear, it loosens up and drives properly. It feels as tho something is jamming it. When the car begins to run as it should, I feel a slight kick, as if something is stuck.
Can I get some more advice? I have some abs codes like code 34 speed sensor. Changed the o2 sensor today and helped a bit, but I have a feeling that the issue will come back. When braking, I feel the car sort of bog/jerk, and a noise from the front of the car. I'm at the point where I'm ready to swap the tranny, but I'd only like to do it as a last resort. Another thing also, today my coolant overflowed after a highway run, normal? I feel the coolant hose and it feels like there's air bubles in it. As you can see CL, this issue has me loosing sleep!
bring the car down in markham i will help u diagnose it.
