sc300: do i cap this vacuum line/ pic request
Old Apr 27, 2012 | 02:44 AM
greens14's Avatar
greens14
Default sc300: do i cap this vacuum line/ pic request
i have a vacuum leak( causing o2 sensor CEL lights periodicallyh and ebrake warning under hard braking)
* ive removed intake manifold a few times adjusting valve clearance. issue occurred after this.
*ive tried using carb cleaner to locate vacuum leak( i guess its too small)?
anyways should i cap this vacuum line( i can hear the suction in it) or do i leave it open. Its in the passenger side of the firewall, pics shown below
and zoomed out
also if anyone could kindly take a picture of their vacuum line routing on the driverside of the engine bay by the intake manifold; it would be greatly appreciated.
Old Apr 28, 2012 | 12:17 AM
greens14's Avatar
greens14
Oh man if no one knows cab somebody take pics of there sc300 outside at least please. Thanks for the help guys
Old Apr 28, 2012 | 06:10 AM
jmorando05's Avatar
jmorando05
I don't see an open vacuum line in either pictur
Old Apr 28, 2012 | 07:22 AM
INTIMAZY's Avatar
INTIMAZY
Mine is open like that as well. Must be part of that mysterious system known as "EVAP"
Never felt if it has vacuum or not. I always wanted to know what it does but always forgot to look it up.
Old Apr 28, 2012 | 08:25 AM
greens14's Avatar
greens14
here !
sounds good sir! its just this issue came out of no where. its either one of these lines or one other thing i might be overlooking. my valve cover broke so im using a random fuel line as a hose which doesnt fit exactly snug. im waiting to stumble upon another valve cover so i can fix that and get it taken care of:
Old Apr 28, 2012 | 08:39 AM
Bflatsharp's Avatar
Bflatsharp
That is your pcv valve it should pull out. 6 dollar part.
Old Apr 28, 2012 | 08:48 AM
Bflatsharp's Avatar
Bflatsharp
The first one is a check valve for the charcoal canister. I would not cap it off.
Old Apr 28, 2012 | 12:28 PM
GS4_Fiend's Avatar
GS4_Fiend
Pcv valve should be on the valve covers not there.
Old Apr 28, 2012 | 01:35 PM
Bflatsharp's Avatar
Bflatsharp
You are right first pic check valve last pic pcv.
Old Apr 28, 2012 | 08:47 PM
greens14's Avatar
greens14
thank you thank you thank you. had no idea it pulled out. i tried pretty hard but didnt want to damage anything. I'll try getting a replacement shortly. hmmm not to find out which vacuum is misrouted!
Old Apr 28, 2012 | 09:20 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
do not cap the first one it is definately a safety relief valve for the evap canister, it will only release pressure if the canister builds up too much pressure before the engine has a chance to draw it in. it is a safety feature that only opens in emergencies so it should not be capped off.
Old Apr 28, 2012 | 09:25 PM
Bflatsharp's Avatar
Bflatsharp
Even a blind squirrel finds a few nuts.
Old Apr 28, 2012 | 09:26 PM
GS4_Fiend's Avatar
GS4_Fiend
Just checked this to confirm. He is right. Don't touch it and leave it alone. It's like that.
6.0PSD
RX - 1st Gen (1999-2003)
Nov 30, 2017 02:33 PM
Meghanw1
Apr 14, 2014 11:37 PM
Piratse
Sep 6, 2012 08:23 PM
ISFFUN
Jan 3, 2012 02:33 PM
FL1PP3D
Oct 1, 2007 12:29 AM
