Where does this intake vacuum line go??
Old Sep 4, 2012 | 06:09 PM
Piratse's Avatar
Piratse
Default Where does this intake vacuum line go??
The plug circled in red(next to the diagnostic port), could someone PLEASE post a pic of where that connects on the other end? Thanks!
1993 sc300 auto.
(EDIT: PIC IS NOT MY ACTUAL ENGINE)
Old Sep 4, 2012 | 06:18 PM
OG Dada's Avatar
OG Dada
Have you tried following where the line leads? I have a 400, but that looks like a vacuum line for the power steering.
Old Sep 4, 2012 | 06:25 PM
Piratse's Avatar
Piratse
There is no line at all. The hose is missing I don't see where it connects.
The power steering LOOKS like it goes there but if you look carfully (I checked my car as well) that line goes into the port close to the block (to the left), just above the main rad. hose. Looks like the same hose though. Unless, of course, my PS hose is connected to the wrong one
Old Sep 4, 2012 | 08:12 PM
cartmill's Avatar
cartmill
it goes to one of the two ports on the PS pressure valve, as you can see in that picture.
one port on that PS pressure valve goes to the intake manifold, the other one goes to that port right above the coolant outlet by the upper radiator hose, which leads to the intake near the air filter, IIRC.
this PS valve just creates a controlled "vacuum leak" to raise the idle up when the PS pressure goes up, so you don't bog down your engine with load from the PS pump.
Old Sep 4, 2012 | 09:07 PM
Piratse's Avatar
Piratse
You are awesome cartmill and King phillip. I will look at it tomorrow and find the proper hose. It was causing my car to idle at like 200 rpm because it was just sucking in air. I capped it for now and it idles much better, hopefully fix it tomorrow.
Old Sep 6, 2012 | 08:23 PM
Piratse's Avatar
Piratse
Thanks a ton you guys, it WAS the PS pump line. It was stuck under the intake runner so it looked like it was hooked up. Thanks!
Dx3
Feb 25, 2010 02:57 PM
no1gsxr
Jan 11, 2010 10:29 PM
UR2klose
Feb 4, 2009 10:31 AM
itssr20
Feb 19, 2007 08:42 PM
SC400-V8
Maintenance
Dec 1, 2005 08:06 AM
