350Z trans adapter?
Old Jan 30, 2014 | 11:12 AM
  #316
babowc's Avatar
babowc
Originally Posted by Ali SC3
I would think if you call some local machine shops they would do that for under $100.
1. You aren't supposed to keep stacking stuff on at the rear end of the crank shaft like that.
2. You area also hurting the idea of keeping rotational mass down
3. too many parts = more things to go wrong or more parts to come loose.
4. Loctite is great and all, but I wouldn't trust it to hold all that together at the end of the day too many variables with the spacer.
Milling it would be the proper way to go for sure, but what I don't understand is why they can't just make the adapter piece a little skinnier instead.
spacing issues?
Although it makes sense to mill the housing, it'd be nice to have conclusive information regarding clutch disc spline engagement along with the pilot bearing engagement.
I guess we'd need the bellhousing length along with the input shaft length and the position of the splines..
Old Jan 30, 2014 | 03:00 PM
  #317
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
well quick was just mentioning in the crank walk thread if you machine the bell housing the dowell pins are gone which is not good, so I guess the solution isnt that simple although he did say about using a twin disc clutch, maybe that solves both problems in one?
Old Jan 30, 2014 | 06:02 PM
  #318
babowc's Avatar
babowc
Just posted in the other thread, but why would machining omit the dowel pins?
If it does, why not just drill into where the original pin was, and replace it with a universal?
Old Jan 30, 2014 | 07:28 PM
  #319
Halon's Avatar
Halon
Good pic of the bell housing removed, I didn't realize it came apart that easy.
Incorrect assumption on the rotational mass increasing, mine was decreased from the stock setup.
Old Jan 30, 2014 | 07:49 PM
  #320
iridebmx's Avatar
iridebmx
if the trans is bolted up why/how would it flex or move just because you dont have dowel pins?
Old Jan 30, 2014 | 08:09 PM
  #321
babowc's Avatar
babowc
Stock AUTO or 5spd?
I assume auto.. which seems pretty obvious since the tq converter is one heavy **** at nearly 40#.
Old Jan 31, 2014 | 07:59 AM
  #322
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I guess it depends on the flywheel used, you could be right about the weight but the problem for me is spacing any weight further away from the crank, doesn't seem right to me but I understand it works.
I think its more of a getting it aligned up perfectly before bolting it down rather than it moving around afterwards.
Old Jan 31, 2014 | 01:52 PM
  #323
PseudoK's Avatar
PseudoK
Has anyone had any success with buying a transmission with grinding issues and replacing the synchros?
there are some really cheap broken ones to be had.
Old Jan 31, 2014 | 05:02 PM
  #324
Halon's Avatar
Halon
Just giving you a hard time. I'm using a lighter weight JWT flywheel which is why overall mass is reduced slightly from my stock 5spd setup. I completely agree it is not ideal having the weight away from the crank, but I like that I can use any off the shelf flywheel clutch setup vs. a custom setup only available from 1 person. When I was doing this I didn't realize anyone was milling the housings keeping mass closer. Good to see newer better ideas/routes being tried here. The goal of me sharing as many pics and info as possible was to share what I experienced, get people talking, get new ideas and hope for improvement. Not to say my way is the way, but just get it all started.
Old Jan 31, 2014 | 10:02 PM
  #325
blackkarma's Avatar
blackkarma
Someone with a r154 currently in there sc please tell me the measurement of the bellhousing to the center of the shift. I may have just found a solution to all of our shifter placement troubles.
Old Feb 1, 2014 | 06:40 AM
  #326
MLeopard's Avatar
MLeopard
I know these measurements are for a W58 but I think they're what you're looking for since that was the stock trans in our cars.
26 7/8" early non-tripod W58
30 7/8" tripod W58
I found these measurements here: http://www.supraforums.com/forum/sho...rement-for-W58
And here I have found mention that the SC tripod is 1/2" shorter than the Supra's tripod that is measured above:
https://www.clublexus.com/forums/showthread.php?t=468761&page=2
Hope this helps.
Old Feb 1, 2014 | 07:06 AM
  #327
blackkarma's Avatar
blackkarma
Will both w58 fit in the sc300
Old Feb 1, 2014 | 07:11 AM
  #328
99SC42's Avatar
99SC42
Back to Topic guys...
Old Feb 1, 2014 | 07:14 AM
  #329
blackkarma's Avatar
blackkarma
This is on topic read my post. I just said I may have solved the shifter length issue for the cd009. I needed measurements to make sure I get it right.
Old Feb 1, 2014 | 07:22 AM
  #330
99SC42's Avatar
99SC42
But all you have to do is cut the tripod bracket and shorten it?? That's what couple guys have done.
