How to remove the black bits on the wind shield trim?
I would like to take off the black trim since its chipping and leave it silver, how should I go about this without scratching the silver/chrome layer?
Thanks for any help, its greatly appreciated.
Also, I have this bigger pin strip sticker thing the previous owner put on the trunk, doesnt look like a heat gun or hair dryer will remove it, should I still try or should i use some goo gone. It almost seems eteched to the paint.
Any decal can be removed with or without a heat gun. Depending on how long the decal has been placed, you might need to compound the paint in order to remove the "ghost" image that is possibly left.
careful with a heat gun, you DO NOT want to overheat/burn the paint! If it were me, I would wait till a very hot sunny day to tackle that sticker. The metal then should be at about 120 degrees and should make the decal much easier to remove. Do not use a metal scraper!, Use a plastic scrapper or an old credit card.
i do auto glass and more then likely the molding is like a "c" an hooks around and stays on the windshield till it comes out
No it's not, it's just paint. Might sound crazy, but what I did on mine was tape as much parts as I can that I don't want the stripsol to touch. And it worked, but I wouldn't recommend it to weak hearts. So scary to even think that the stripsol is gonna damage the paint.
Unscrew the vertical trim pieces then just use a plastic puddy knife to pry up on the trim aqn then carefully un snap the plastic wedge clips, Its easy really
How do I unscrew the vertical trim peices? I don't see any screws lol.
Gonna try to remove it and then use stripsol like mentioned above.
