2jz-ge Help!!
Old Apr 3, 2012 | 11:20 AM
ScWift92's Avatar
ScWift92
Unhappy 2jz-ge Help!!
I Am Dropping Out My 2jz-ge From one of my sc300's and ive been looking all over For DIY's But no Luck .
All Im Doing is swapping over motor and tranny because my tranny is shot only goes threw 3 gears and holds gears KEEP IN MIND CAR HAS 222000 Miles Any info on dropping it or a DIY That will help???
Thanks In Advance.
*I Have Searched Left And Right Still No Luck*
Old Apr 3, 2012 | 12:36 PM
ScWift92's Avatar
ScWift92
Bump!!!!!!!!
Old Apr 3, 2012 | 12:51 PM
poorsupra's Avatar
poorsupra
are you trying to just pull your 2jzge with trans and put in another 2jzge/trans of the same year? it will be easy, disconnect all lines, connections, motor trans mounts, swap. straightforward. but IMO if you have to ask you probably will have trouble doing this. label everything, color code stuff, and if you have common sense you can do this.
Old Apr 3, 2012 | 02:46 PM
INTIMAZY's Avatar
INTIMAZY
Just start unbolting sh#t.
Doesn't matter what it is.
Eventually the motor will fall out on its own.
Old Apr 3, 2012 | 06:12 PM
ScWift92's Avatar
ScWift92
whats the easiest way to pull it out?
And Yes one to another.
Old Apr 3, 2012 | 07:44 PM
INTIMAZY's Avatar
INTIMAZY
Take the hood off and take it out in one piece with trans attached.
Why exactly are you replacing the motor when only the trans is broken?
Old Apr 3, 2012 | 08:50 PM
ScWift92's Avatar
ScWift92
will tow straps work? and because motor feels weak two. and loss of compression.
Old Apr 3, 2012 | 09:04 PM
Rising_Sun's Avatar
Rising_Sun
Have you tried flushing the transmission? Any slippage will make the car feel sluggish. Pulling the motor is a no brainer, just rent an engine hoist.
Old Apr 7, 2012 | 11:43 AM
ScWift92's Avatar
ScWift92
yeah i replaced the transmission fluid its not slipping it just feels sluggish and car only goes threw 1-3 gears 4th doesn't exist .
** Update motors almost out one car just have to disconnect mounts and driveshaft Keep In Mind Im Doing Motor And Transmission.
Old Apr 7, 2012 | 11:57 AM
ScWift92's Avatar
ScWift92
Any Tips On Saving Time And Hassle Guys ? This Is Clublexus Right Im Not On The Wrong Forum???
Old Apr 7, 2012 | 12:57 PM
2jznosht's Avatar
2jznosht
Um, take it to a shop...you either spend time or money when a car needs work done
Old Apr 9, 2012 | 07:15 PM
CDN-TEX's Avatar
CDN-TEX
ScWift, just did this this winter. A few things I learned...use a 2 ton jack, it will reach over everything i.e.: front bumper. If you use a 1 ton you will have to remove front bumper and metal bumper bar. I took off the air conditioner compressor and left all the lines intact. I left the wire harness on the engine so I unplugged all connectors, lines, cables and I taped and labeled everything. Have containers to catch all fluids like coolant and tranny fluid. Jack car up on stands, extra space will help. Plan on new engine mounts, many are torn already or in the process of engine removal. Remove rad, fan. When you are taking out the engine/tranny you will have to tip it at angle, watch the tranny fluid that will run out. Having the repair manual will help with everything.
boostinsc
Nov 19, 2010 08:33 PM
TurboCoupe
SC400 / 300 Classifieds
Aug 16, 2004 11:45 PM
