I really need some help with this guys.
Old Apr 17, 2012 | 07:55 PM
  #31
dontmachme's Avatar
dontmachme
my sc400 is doing the same thing it runs rough on idle. ive either got a small blown head gasket which sometimes have no symptoms but exist anyway or a valve isnt opening all the way because i can hear a lifter tapping. test your coil packs and try changing the igniter. it controls the dewll of your spark to (on time) with tdc and if its bad it might make one plug fire at the slightest wrong time. and fuel cleaner is a bad idea. if one plug is burning lean and the others arent thats an injector issue.
Old Apr 17, 2012 | 10:53 PM
  #32
GS4_Fiend's Avatar
GS4_Fiend
You put a new MAF sensor and it's still got a CEL on for bad MAF sensor. Obviously, your problem is a wire integrity problem. Check for an open/short in the MAF sensor circuit. Trace from the MAF sensor all the way to the PCM for broken wires. It's gonna be quite a task.
LS400FAN
34
Nov 30, 2020 05:47 PM
GS4hunnit
Sep 5, 2014 01:40 PM
Notic
IS - 1st Gen (2001-2005)
Jun 18, 2012 04:02 AM
mahtogje
Apr 7, 2010 12:54 AM
sweetsc400
Aug 8, 2003 05:15 PM
