Heater Control Valve
Old Mar 15, 2012 | 01:24 PM
BlaineyB's Avatar
BlaineyB
Default Heater Control Valve
OK well about a few months ago, my mechanic and I bypassed and removed the heater control valve and rerouted the hoses to makes my heater work thinking my A/C doesn't work, today i tried my A/C and it's cold. question is do I need my heater control valve to run my A/C and is it safe? will it cause and damage to anything? thanks cl. I have a 92 SC400 btw.
Old Mar 15, 2012 | 01:31 PM
scviolence's Avatar
scviolence
I bypassed mines like 2 years ago... Ac and heat still work No problems dont worry about it lol.
BlaineyB's Avatar
BlaineyB
Bumpppppppp
Old Mar 15, 2012 | 01:32 PM
BlaineyB's Avatar
BlaineyB
thanks scviolence. so whats the heater control valve used for? so did you remove yours also?
Old Mar 15, 2012 | 02:01 PM
BlaineyB's Avatar
BlaineyB
Bumpppppppp
Old Mar 15, 2012 | 02:51 PM
Nysc300's Avatar
Nysc300
Heater control valve controls the heat it opens and closes. Now that it is bypassed if you notice the heat is never really off you can still feel the heat comming out the vents when you drive. As for problems I haven't run into any at all and it's been a whole year like that.
Old Mar 15, 2012 | 06:17 PM
SFrymyah's Avatar
SFrymyah
Did you bypass the whole valve or swap the vacuum line? When it gets warm out, just swap the vacuum line back to how it was and you're in good shape.
Old Mar 15, 2012 | 07:26 PM
Nysc300's Avatar
Nysc300
No I left the vacuum lines connected to the heat control valve and bought a cheap 2$ pvc pipe at auto zone and just removed the 2 main lines and ran the to the PVC pipe.
Old Mar 15, 2012 | 10:35 PM
BlaineyB's Avatar
BlaineyB
i removed my heater control valve.
americk22
Jan 25, 2023 07:34 AM
dirkdiggle
Maintenance
Nov 4, 2008 07:16 PM
